...because I'm lost when it comes to trying to make a CD that can be played in my Playstation 2. I'm trying to get a .mpg file onto a CD, so I can watch it in PS2. But I don't know if I have to convert it at all first :/ Do I have to change it over to .avi in order for it to be playable (as the guide says PS2 can only play CD-R in DivX format)
Then do I need to do anything special when burning it to CD? Or do I just burn the file to disc, and I'm good to go?
- Thanks much in advance!
I don't have a ps2 but i think that you cannot play burnt movies without a chip. The only way would to get a chip and burn movie files as a dvd, the ps2 doesn't accept vcd format or others. hope this helps
My standard PS2 will play a backed up DVD. The only way would be to convert your MPG file to DVD Compliant MPG and burn to DVD .
But it doesnt look like you have a DVD Burner. -
PS2 cannot play any sort of movie on a CD wether its mpg/vcd/svcd or whatever.
You have to find the ps2 mediaplayer try looking at ps2newz.net, ps2ownz.com, or cdrom-guide.com ps2 forums for more info.
It will work but you will need a modchip or swap magic disk to make the divx movies work on a cd-r.
Stupid Flanders with his stupid iLoHD04 problems!
By Batchman in forum DVD & Blu-ray RecordersReplies: 33Last Post: 4th Mar 2011, 18:41 -
i know this sounds stupid but...
By cthuggha in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 30th May 2009, 10:02 -
Avidemux .. I must be stupid
By bvdd in forum Newbie / General discussionsReplies: 9Last Post: 1st Mar 2009, 18:06 -
Probably a stupid question, BUT...
By HmNtr in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 7th Dec 2008, 13:22 -
New to burning: Am I stupid?
By Eat Right in forum Newbie / General discussionsReplies: 1Last Post: 8th Jun 2008, 13:47
