  1. I recently switched to Windows 2000 and I cant get any MP3 encoder to see my drives. I know its an ASPI problem but i've tried the last three versions, ForceASPI, and even a Win2k/XP registry fix to no avail. Does anyone know what the problem is?
  2. Originally Posted by bladestorm
    i believe forceaspi will remove aspi too, you might try doing that, restarting and then installing aspi again.
  3. Reinstall ForceASPI first and then run the ASPI Check utility and see if it reports v4.60 build 1021. You may also have problems running it unless you have the latest service pack for Win2000 installed.
    Afterdawn has a moniker saying to use Adaptec's latest version. DO NOT DO THIS! It did not work on any of my machines that run Win2000 Pro with SP4, but overwriting it with ForceASPI worked.
  4. I do have the latest service pack and have also done what you two have said to no progress. What else could be the problem?
  5. Member Abbadon's Avatar
    Dec 2003
    Caribbean Sea
    Make sure you are not trying to rip a CD with DRM or some kind of copy protection.
    No tengo miedo a la muerte. Solo significa soņar en silencio. Un sueņo que perdura por siempre. ..
  6. Make sure you are not trying to rip a CD with DRM or some kind of copy protection.
    I'm not. Besides, if it cant access the drive how could it tell if it's protected?
