I'm trying to frameserve a video file from VirtualDUB to TMPGEnc (latest version) and TMPGEnc keeps giving the "cannot read file or unsupported" error. The codecs are loaded properly, GSpot reports DivX video with all codecs installed. The Directshow Multimedia Reader is set at priority 2 at the top of the list. Still getting the problem. Not sure what to try next. Ideas?
I had to reboot before i did frameserving,did you try that yet?
Got the same problem. I've had done several movies van divx to dvd without a problem. The movie tears of the sun gave me the same problem as you discribe.
I am busy doing the movie on "the long way" (saving as avi in virtualdub (extreme big files (38 gig)) and then using tempenc for dvd) -
I did get it fixed, although I don't know what the exact problem was. I went back and uninstalled TMPGEnc and VirtualDUB entirely and then did a clean install and it worked. Wherever the problem was, the fresh install fixed it.
Thanks for everyone's suggestions! It's nice to know that there are knowledgeable people around.
Read error with TMPGEnc
By MasterScreech in forum Authoring (VCD/SVCD)Replies: 2Last Post: 24th Jun 2010, 19:08 -
VirtualDub Won't read FLV Files
By Markgc in forum EditingReplies: 24Last Post: 20th Nov 2009, 19:25 -
TMPGEnc Read Error
By koberulz in forum Video ConversionReplies: 0Last Post: 6th Nov 2008, 21:44 -
Mpeg-1 Audio Layer 2 - Audio Tag 50 - VirtualDub, TMPEGEnc Can't Read
By Rebooter in forum AudioReplies: 2Last Post: 26th Oct 2007, 21:51 -
Are there any ffmpeg builds that will read VirtualDub frameserves ?
By vhelp in forum Video ConversionReplies: 6Last Post: 1st Aug 2007, 02:00
