Lite On LDW-411S
http://www.newegg.com/app/ViewProductDesc.asp?description=27-106-921&catalog=5&manufac...=BROWSE&depa=0
NEC ND-2500A
http://www.newegg.com/app/ViewProductDesc.asp?description=27-152-012&catalog=5&manufac...=BROWSE&depa=0
Sony DWU14A
http://www.newegg.com/app/ViewProductDesc.asp?description=27-131-222&catalog=5&manufac...=BROWSE&depa=0
Sony DW-U14A
http://www.newegg.com/app/ViewProductDesc.asp?description=27-131-214&catalog=5&manufac...=BROWSE&depa=0
TDK 440N
http://meritline.com/tdk-440n-dvd-burner-bare-drive.html
I am leaning toward the liteon as it is ammong the cheapest and seems to keep the fast cd burning. I have had great luck with my lite on cd burner so i would think they would keep up the quality. I have a bunch of dvd-r's a friend gave me so that is the speed i am really concerned with.
What is the recomended drive here? Is there another one around this price that is better?
Thanks alot for the help.
people say NEC 2500a is the best, and one of the cheapest.
Lite-on is good too.
Plextor is suposedly the best of the best, but more expensive.
So go on that -
I just purchased the NEC2500 and am happy with it. I have only burned 2 data dvd's so far for archiving. I burned one +R and one -R. Both burned fine. Nero successfully verified the data after the burn and I also put the dvd's into my LiteOn combo drive and used DVDInfoPro to do a read error check and it found no errors. I will probably try burning a video dvd this weekend, but I am happy so far. Also, for the 4x +R disc it offered a 6x burn speed.
Looking for best PC drives
By tpapictures in forum Blu-ray RippingReplies: 26Last Post: 6th Apr 2012, 11:45 -
media drives
By c-raig in forum Newbie / General discussionsReplies: 3Last Post: 21st Jun 2010, 05:13 -
Old drives in new DVR?
By cwb in forum DVB / IPTVReplies: 5Last Post: 1st Jun 2010, 22:29 -
Hard Drives
By hardy in forum ComputerReplies: 16Last Post: 27th Jun 2009, 19:00 -
Drives will not refresh
By JWT in forum DVD & Blu-ray WritersReplies: 9Last Post: 29th May 2007, 10:29
