w2k
  1. helo all,wonderfull forum here,i was wondering if i should install w2k on this sytem:534mhz celeron,32mbpc100 sdram,8.01gb hdd,32mbgeforce2mx200 pci,w98se.
    I currently have w2k and soon will have a 64mbstick too,some have told me to just install it and just install the ram when it comes but others have said to wait untill i have that ram,should i wait or just install it?
  2. Microsoft says minimum system requirements 64 megabytes MB of RAM for 2000 pro.
    Good luck.
    Mar 2002
    Hawaii
    I have a laptop with very similar specs, that I use at work. The cpu is a little slower - It's a 400Mhz K6. Anyway, the only difference is that my laptop has more RAM, but I don't think that will be a problem, if you have some on the way.
  4. I have a desktop that has worse specs than that (except RAM) and it runs fine. It does take 2 minutes to boot, but after it does things work good.
    The specs are Pentium 2 350MHz, 256meg RAM, ATI All-in-Wonder Pro.
    You'll probably need that extra RAM, but everything else is fine
    "A beginning is the time for taking the most delicate care that the balances are correct."
    - Frank Herbert, Dune
  5. The Old One SatStorm's Avatar
    Hellas (Greece), E.U.
    I don't suggest w2k for your PC. I suggest w98se or (if this is possible) w95se.
  6. Why do you need w2k? You're at the minimum for specs (I never install it on less than 128MB, and prefer 256). It'll probably work, but what do you hope to gain?
    I'd stay with 98se. But if you DO go to 2k, go to www.blackviper.com and follow his recommendations on disabling some processes you don't need. This will help get the best performance from your older machine.
  7. Well i want to go to w2k so i can use adobe photoshopcs,latest version of windowblinds and not be stuck with 4 gig file limits.
