Hi there.
Well, what i need to do is to Re author a existing DVD, and insert a new audio stream.
The way i do it now is:
1. I rip the DVD
2. I encoded to divx avi with no sound
3. I edit the audio (so it will sync with the ripped divx) in Adobe Premiere.
4. When audio and video are correct i use TMPGEnc to make a MPG2 for a new dvd. Using the edited syncronized audio and my avi with no sound.
I think there must be a better way to edit my audios and add them to a video with out decoding to AVI and losing quality in the process.
Maybe a authoring tool where i can directly edit my new audio from a .VOB maybe?
Any advices?
You know you can rip the video from a DVD in M2V format. Perhaps Premiere works with M2V ... I don't know ever used it.
If you still have to create an AVI to work with Premiere (or to have something to sync the audio too) then render the audio seperately and match it up with the M2V and just delete the AVI
Then import the M2V and your audio into your DVD authoring program.
Tis a thought
- John "FulciLives" Coleman
P.S.
BTW there is a version of VirtualDub that will allow you to import the M2V or even VOB files."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
TMPGEnc Author Keeps Re-encoding
By lostinspace00 in forum Authoring (DVD)Replies: 13Last Post: 8th Apr 2011, 08:16 -
Any way to keep TMPGEnc Author 4 from Re-Encoding video ?
By RWANDREWS in forum Authoring (DVD)Replies: 7Last Post: 3rd Mar 2009, 09:43 -
audio encoding: tmgenc dvd author 3 vs. tmpgenc plus
By cL0N31 in forum Newbie / General discussionsReplies: 0Last Post: 6th Jan 2009, 23:25 -
Author without re-encoding?
By digitalfreaknyc in forum Authoring (Blu-ray)Replies: 13Last Post: 24th Jul 2008, 10:21 -
TMPGEnc DVD Author 3 - Stopping it Re-encoding
By Incast in forum Authoring (DVD)Replies: 12Last Post: 8th Aug 2007, 17:45
