  1. I downloaded the demo of Honestech Mpeg Encoder and it appears to be a good alternative to Tmpgenc...
    However I can not frameserve to it using VirtualDub... When I open the VDdub file "marx.vdr" (converting my VHS Marx Bros movies to DVD) I get an error that this file type is unsupported by Honestech....
    I also tried renaming the VDub frame handle with an avi extention, I get the same error.... I can open the unserved avi fine in Honestech...
    Is there a way to frame with VirtualDub to Honestech as there are some VDub filters I use when I am frameserving to Tmpgenc....
    Again I have no problem frameserving to Tmpgenc....
    Also is there a way to change the video resolution in Honestech from full DVD (720x480) to 352x480 ? When I use the builtin Honestech template it defaults to full DVD and is greyed out... (will not allow me to change)....
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    try using vfapiCONVEN.exe on your vdr file
    https://www.videohelp.com/tools?tool=139#comments
  3. Thanks very much worked... But the resulting mpeg had audio only. The video was a black screen through out the entire mpeg...
    Using Tmpgenc I was able to successfully from VDub frameserver and the mpeg had both video and audio....
    What could be wrong...
