I have been converting Divx movies to DVD NTSC using Canopus Procoder. For the most part I have had good success in authoring the converted files with DVD Lab and then burning good, working DVDs.
Occassionally I run into a problem where the converted Divx file is too large for a DVD once I author it. Actually the converted m2v and wav files are too large.
What is the best way to get around this problem? I looked for a guide but didn't see anything relevant.
Can I shrink my converted m2v and wave files? Do I have to reconvert the Divx file using a lower data rate? If so how do you know what you are going to end up with?
Calculate the video bitrate before you convert.
www.dvdrhelp.com/calc
www.dvdrhelp.com/tools for more bitrate calculators.
You can also compress your wav to mpa or ac3.
Should converted .mp4 file be this large?
By brassplyer in forum Video ConversionReplies: 9Last Post: 3rd May 2011, 14:17 -
DVD player can't read large DIVX files
By Alistair George in forum Authoring (DVD)Replies: 14Last Post: 27th Jan 2009, 18:16 -
converted DIVX files are white using ipod presets
By djhurlbu in forum ffmpegX general discussionReplies: 5Last Post: 4th Feb 2008, 01:31 -
Converted file too large for DVD.
By Dave H in forum SVCD2DVD & VOB2MPGReplies: 12Last Post: 18th Oct 2007, 19:08 -
Dr. DivX converts large VOB files into tiny unusable divX files
By texas1 in forum Newbie / General discussionsReplies: 2Last Post: 6th Aug 2007, 21:44
