Can anyone tell us if you can convert divx to avi and what progam would you need to use?
The film is recognised as an avi but our programs cannot convert to DVD without the correct codec.
Many thanks
Results 1 to 9 of 9
You still need to install the codecs to use it. If you don't have the codecs you can't access the file.Originally Posted by Timmychuck"Art is making something out of nothing and selling it." - Frank Zappa
I don't know if this is where he was coming from but I am asking the same question. Regardless of the extension, the streaming format is completly different than that of a .raw avi file. I am wanting to take a divx avi file and burn it as a dvd. The dvd authoring software I have (Sonic mydvd) allows mov mpg and avi as sources however any divx coded source it rejects. Is there a converter to "uncompress" the stream back to raw? Or I could just do a playback/streamrip if anyone knows of a good freeware package...
Thanks!
Kev...
kevflynn@adelphia.net <--- respond there please! thanks again. -
You need to have a Divx codec installed in your computer so you can read and play the Divx avi file. Then you need to save it as a Type 1 or Type 2 DV avi file. To do that, you'll also need to have the right type of DV codec installed in your computer, or the right software. VirtualDubMod is picky, for example. Or you may need to go back to VDubSync 1.4.13, the withdrawn version that included Divx 3.0. Then you need to use an MPEG-2 encoder to encode the Type 1 or Type 2 DV avi file into MPEG-2. Then you need to split the MPEG-2 file into elementary streams, convert the audio to ac3, author and burn the DVD.
Even after all that, the DVD will still look like junk. Divx looks okay when played on your compute rmonitor -- it's optimized for that. But try taking the TV out from your video card and looking athte playback of the Divx file on your TV. It looks godawful. Lots of color banding, lots of macroblocks, etc. etc.
A downloaded video file should be viewed on your computer. It'll look like garbage if you convert it to a Type 1 or Type 2 DV file, encode it to MPEG-2, and burn it to DVD. But it's your time to waste. -
I have taken a couple of very well encoded DivX files, encoded them to mpeg-2 (the DV step is a waste of time and energy), and they have come up looking at least as a good as a VHS version. Given these have been rare films originally shot in 16mm, I could not expect better. The only intermediate step I take is demux the audio in VirtualDub to prevent sync issues.
1. Demux audio in VirtualDub (full processing, save as uncompressed wav)
2. Encode as elementary streams using (insert favourite mpeg-2 encoder here)
3. Author and burn
4. Sit back and watch
QEDRead my blog here.
You might give TheFilmMachine a try. It was made to convert AVI, especially XVID and DIVX to DVD. Freeware, works good for most XVID and DIVX. Easier than TMPGEnc for first timers.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
Can't convert avi to an avi that the my divx player will read.
By aarelovich in forum Video ConversionReplies: 5Last Post: 4th Feb 2010, 06:19 -
divx to avi with divx author
By pred in forum Video ConversionReplies: 4Last Post: 12th Nov 2008, 23:32 -
avi to DivX using divX converter pro
By Deaf Raiders in forum Video ConversionReplies: 3Last Post: 19th Dec 2007, 13:28 -
Convert this avi to DivX avi (GSpot Screenshot included)
By indiannawaf in forum Newbie / General discussionsReplies: 13Last Post: 22nd Aug 2007, 11:26
