I have a movie file (.avi, about 700mb) that I've been working with for a couple days. I encoded it with TMPG, but the audio was quite out of sync. I scanned the original .avi file for bad frames in VirtualDub, and it said 801 frames masked, 20 bad frames, 821 frames good but undecodable. I'm assuming if I can get rid of the bad frames that I'll be able to encode with TMPG and the audio will be ok, is this correct?
How do I get rid of these bad frames? Can I just save the avi as a new file after VDub scans it for bad frames, and it will save it without the bad frames? (I just have the regular version of VirtualDub, is that ok, or do I need to get a different one?)
One more thing. Is that alot of bad frames to have? I mean is it going to affect the movie once they are taken out?
I'd really appreciate any help!
Thanks!!!!!
I think I accidently posted this in the wrong forum. That's a first for me....
Sorry about that....
But thanks so much for the reply!!!!
Remove Duplicate Frames
By robindean in forum Video ConversionReplies: 26Last Post: 11th Mar 2010, 15:30 -
.avi file cannot be repaired - need to remove bad/corrupt frames
By realtechtalk in forum Video ConversionReplies: 0Last Post: 7th Sep 2008, 12:27 -
How can i remove/fix some broken codecs?
By GangstaRap in forum Newbie / General discussionsReplies: 23Last Post: 23rd Feb 2008, 04:04 -
Fix for skipped frames?
By Tom in HD in forum MacReplies: 1Last Post: 15th Dec 2007, 17:44 -
Remove green color from 49 frames
By mlong30 in forum EditingReplies: 5Last Post: 10th May 2007, 23:54
