I have a couple of files that my windows media wouldn't download the codec for; apparently it is SP44... any suggestions on where to get that codec and how to convert this AVI to MPG?
Results 1 to 10 of 10
its in one of the below codec packs -- but i cant recall which one ... ads uses it also ...
http://www.afreecodec.com/codec_pack.php"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
hi !
i have the same problem i cant find the sp44 codec ????
any indeas where i can get the codec ?
cu cracy -
thanxx i know this site but there is only a description of the codec
but no download ... i searched for two days an canīt find this codec ...
could it be that this codec is in some software included ?
cracy -
i mentioned already above it is listed in a codec pack on the link i gave above --
Did you try this link to a download on that page?
http://www.logitech.com/pub/techsupport/quickcam/cs510/cs510_patch.exeI think,therefore i am a hamster. -
good one ... thats a working link
i think it supposed to be in here also
http://www.adaptec.com/worldwide/support/driverdetail.html?sess=no&language=English+US...vc1100_v12.exe"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 15:10 -
Which Codec's is Best To Use?
By Artic in forum Video ConversionReplies: 4Last Post: 26th May 2010, 15:39 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 20:40 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 10:41 -
BD Codec?
By kinglerch in forum Blu-ray RippingReplies: 4Last Post: 1st Aug 2008, 21:26
