Just 2 Capture questions when going from a DV Camcorder to pc via firewire.
Will be making home movies onto DVD & want to keep best quality.
Capture Choices are:
DV-Type 1 or 2 which makes large .avi files
or
DVD = .mpeg-2; 29.97 fps; 720*480 which is much smaller files
???Is there any reason to capture with the larger .avi format or will using .mpeg-2 look just as good?
Also: mpeg-2 has audio options of:
LPCM
or
Dolby digital (ac-3) 2.0
???Which to choose & why?
Thanks!
Source > avi > mpeg2 > DVD-r disk is widely regarded as the better, but longer, option and gives you the ability to edit your capture before you encode and author to disk.
Source > mpeg2 > DVD-r disk is far quicker and depending on the capture codec/software you use and the speed of your PC (quick-ish PC required to capture directly to mpeg2).
Will Haytgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
what's best for you might depend on the software you use.
i once captured dv tapes to mpeg2. it looked good on the computer, but when edited and burned the movie was faltering (so to say) about every second.
when i captured as avi the result was perfect.Music was my first love, and it will be my last -
If you're going to edit the video (to clean up the audio or video) or want to make cuts at a specific frame instead of only on key-frames, bring it in as DV AVI. (Don't know if type1 or type2 is better, look at the links on the left.)Originally Posted by mrvnsu
If you're *not* going to edit your video prior to putting it to DVD, go ahead and try capturing straight to MPEG2 with AC3 audio.
Aspect Ratio setting in VirtualDub Capture mode
By alesco in forum Capturing and VCRReplies: 34Last Post: 6th Feb 2012, 10:23 -
setting region with AVS and a Nero question
By Willy Bee in forum Authoring (DVD)Replies: 2Last Post: 21st Feb 2010, 23:21 -
setting to capture 30p(progressive mode) from canon HV30?
By yunakokimama in forum Capturing and VCRReplies: 3Last Post: 27th Oct 2008, 02:39 -
Setting up capture card for video out to play on TV
By wiseant in forum Capturing and VCRReplies: 2Last Post: 28th Jul 2008, 18:57 -
Suggestions request for setting up PiP PC capture.
By Clickn in forum Capturing and VCRReplies: 0Last Post: 21st Apr 2008, 20:52
