Ok, this is a great program, though, many improvement needed. So, please donate to get the full app and help the author makes this app better.
This program is very very picky on the mpg & bin files. So, if there're something going wrong, that because your mpg/bin files are not very good (even your files play flawlessy on your dvd player or computer, it doesn't mean that they're good enought for svcd2dvd.)
How to fix the darn not so good mpg/bin files, use vcdgear, just load the mpg/bin files and output to mpg files. Do not check "fix mpg", it's only screws up the files more.
Still doesn't work, use ulead studio 7, load the mpg, then save the trimmed video option, that will guarranty a good mpg files for svcd2dvd.
Well, this is my experience w/ svcd2dvd after making tons of dvds. Again, great great program, just need to be more tolerate with mpg/bin files.
TQ
YEs i agree. I found out the same problems so i did exactly the same thing with vcdgear. But when that didn't fix the problem i simply extracted the audio as wave and used an encoder to re-encode the WAV file to MPEG audio, then used TPMPEG to multiplex the audio back, and found it went through svcd2dvd without any problems.
Maybe another enhancement would be to add multi channel mpeg audio encoding if the source is of course multi channel. -
I have a question about this. I trimmed the video in US7. but now i don't have any audio anymore. Also the preview doesn't give any audio.Originally Posted by drti2
Do you have any idea.
guido
help for svcd2dvd
By dougal69 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 12th Sep 2011, 18:05 -
Svcd2dvd
By dobbin in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 24th Jan 2011, 12:19 -
New to SVCD2DVD Help!!!
By Marts1988 in forum Newbie / General discussionsReplies: 2Last Post: 4th Jan 2011, 12:45 -
How can i find which tipe of subtitel can read my dvdplayer?
By iamandi in forum SubtitleReplies: 2Last Post: 24th Jun 2008, 14:26 -
MTR can't read DVD... READ ERROR: Can't Open IFO.
By strathq in forum MacReplies: 16Last Post: 17th Jun 2007, 00:04
