Results 1 to 19 of 19
  1. I'm sorry if this is a topic posted elswhere on the forum. I've looked briefly but have run out of time.
    I'm capturing with and ATI 128 PRO PCI. I'm using MMC 7.2 (I've tried newer versions but without success--the TV function simply refuses to run).
    The problem is the audio is not captured in 48khz. I think it is 22.1 or something. What is the best way to resample it (preferably with freeware). I always convert my audio to AC3. I attempted to do this as well as resample to 48khz with ffmpeg, but the resulting file was significantly out-of-sync with my video.
    Is there a way to resample and not alter the length of the audio? Can I resample from the mp2 format it is captured in or would I have to first convert to .wav then resample, then convert to AC3? Thanks
  2. Cool Edit Pro does it just fine but would be a waste to spend $299.00 for just Sample Rate Conversion. I'll bet every application with a lot of zeros in their price could do a good job.
    Have you tried SSRC? It should be in the Tools section. SSRC (Shibatch Sample Rate Converter) is made for just one thing. Its FREE, so i know the price is right.
    Two versions are included; SSRC.exe, and SSRC_HP.exe (Hi-Precision).
    It is a command line utility, but i know there is a GUI around for it.
  3. Member spidey's Avatar
    Apr 2001
    U.S.A.
    You may simply plug SSRC into TMPG or use it via BeSweet for any and all of your audio conversion needs
    ~~~Spidey~~~
    "Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards
  4. Get Slack disturbed1's Avatar
    Apr 2001
    init 4
    wavefs44. Better sounding than SSRC (IMO of course). Pretty slow, it's the same routines that DVD2Avi uses to resample. It's a CLI program, or can be used by TMPGenc. If you can read Japanese (bablefish ) http://hemiolapei.free.fr/Music/src/src.html compares SSRC and WaveFS44. With WaveFS44 coming out on top, though slower. There's a link on the page for it, the package is called WCONV04A.LZH
    Other than SSRC and WaveFS44, there aren't many freeware apps to do a quality job. Most usually just set the new sample rate and apply clipping. You'll end up with bad sound and different length file.
    For payware, try Cool Edit or Sound Forge.
  5. I use SSRC_HP.exe (Hi-Precision) with TMPGEnc. It requires only a quick edit of the "TMPGEnc.acf" file.
  6. Does wavefs44 upsample?
  7. Originally Posted by au7usa
    Where'd you get that at?
  8. Get Slack disturbed1's Avatar
    Apr 2001
    init 4
    Sure does.
    Microsoft Windows 2000 [Version 5.00.2195]
    (C) Copyright 1985-2000 Microsoft Corp.
    Wave sampling frequency converter(wavefs44) version 0.4
    Copyright (c) 2000 by WTC
    usage : wavefs44 <name1> <name2> [g<gain>] [p<0..3>]
    name1 : source wave file name
    name2 : destination wave file name
    ggain : amplitude parameter
    p<0..3> : precision(0:low, 1:mid, 2:High, 3:UltraHigh)
    s<{32|48}> : output Fs(32:32kHz, 48:48kHz, none:44.1kHz)
    q : quiet(suppress in-progress message)
    C:\Documents and Settings\disturbed1>
    You can resample to 32, 48, 44.1. 44.1 is the default and doesn't require the s switch.
  9. I thought from the name that is was specifically designed to change the sample rate to 44.1. Guess i never looked.
    See kids, this is what happens when we ASS-U-ME!
    Shibatch Audio Tools Homepage:
    http://shibatch.sourceforge.net/
    The package available here (ssrc-1.29.zip) contains both SSRC.exe, and SSRC_HP.exe, as well as source.
  10. Get Slack disturbed1's Avatar
    Apr 2001
    init 4
    Just wondering, what's SSRC_HP? High Precision?
    And is it better than just SSRC. I actually didn't like the quality from SSRC. High frequency responce seemed tainted to my ears.
  11. to disturbed1:
    Try the "--twopass" option, it might be clipping that your hearing.
  12. Get Slack disturbed1's Avatar
    Apr 2001
    init 4
    Thanks, did SSRC_HP in 2pass mode.
    I must say it does sound better than an SSRC single pass. Though I still think the edge belongs to waveFS44. However the speed difference is incredible (2x maybe 3x faster). For perfect results I'll use waveFS44, and when in a hurry looks like SSRC_HP will be the way.
    I used these 2 commands (anything I should change?)
    ssrc_hp.exe --rate 48000 --twopass --dither 3 --bits 16
    dither 3 is the ath based noise shaping which didn't work the way I thought it should.
    and this one
    ssrc_hp.exe --rate 48000 --twopass --dither 1 --pdf 1 --bits 16
    The latter one produced the better results, with less high frequency noise and clipping. I think SSRC dithering is broken.
  13. Yeah, the speed advantage comes at a price. When you turn all of the switches on works fine though.
    Recommended settings for SSRC are here:
    http://www.hydrogenaudio.org/index.php?showtopic=17135&
    They seem to agree with you on SSRC dithering being broken.
    From what i gather of WaveFS44.exe (i don't read Japanese), it supports just the three sampling frequencies? Not really a problem if your using with TMPGEnc, its interface only supports the three. 48kHz / 44.1kHz / 32kHz
    Looks like it was made with TMPGEnc in mind!
    WaveFS44 seems to do a descent job, but i'll have to continue torture testing it.
    Looks like i got another toy, Thanks!
  14. Get Slack disturbed1's Avatar
    Apr 2001
    init 4
    I just don't know which precsion level TMPG uses by default.
    I use AZZA Gui, and made a custom GUI for waveFS44. Shame the azza site seems to be down. This is a great little GUI writer for CLI programs.
    Heres a screen shot
    And the .gui file for it
    [Main]
    Description=Wavefs44
    Folder=wavefs\
    CMDLineProgram=wavefs44.exe
    Path=C:\Documents and Settings\disturbed1\Desktop\Vid Apps\Wavefs44\
    [Page1]
    Description=Options
    Item1=Option1
    Item2=Option2
    Item3=Option3
    Item4=Option4
    Item5=Option5
    [Option1]
    Description=Wav File Input
    Type=Edit
    Subtype=File
    Parameter="%1"
    [Option2]
    Description=Wav File Output
    Type=Edit
    Subtype=File
    Parameter="%1"
    [Option3]
    Description=44khz?
    Type=Check
    Parameter=s44
    [Option4]
    Description=48khz?
    Type=Check
    Parameter=s48
    [Option5]
    Description=Precsion?
    Type=List
    Description1=1
    Parameter1=p1
    Description2=2
    Parameter2=p2
    Description3=3
    Parameter3=p3
  15. Those settings are in the "TMPGEnc.acf" file.
    [wavefs44:resample:param]
    " %s":SrcFileName
    " %s":DestFileName
    " g1"
    " p2"
    " s32":SamplingFrequency_32000
    "":SamplingFrequency_44100
    " s48":SamplingFrequency_48000
    I alter the settings all the time, go ahead and chang em.
    (Just remember to backup you old file: TMPGEnc.acf.BAK)
    Here's what i added for SSRC_HP.exe:
    First i just added a new line to the index section at the top;
    [info]
    toolame*.exe=tooLAME
    LAME.exe=LAME
    SCMPX.exe=SCMPX
    WaveFS44.exe=WaveFS44
    SSRC.exe=SSRC
    SSRC_HP.exe=SSRC_HP
    Then i just copied the SSRC section and pasted it below, renaming SSRC to SSRC_HP, (and added a few tweaks)
    [SSRC_HP:info]
    Name="SSRC HiPrecision"
    SupportMethod=resample
    Resample.InterfaceType=CommandLine
    Resample.SupportInput=all
    Resample.SupportOutput=all
    Resample.SupportChannels=all
    [SSRC_HP:resample:param]
    " --rate %s":SamplingFrequency
    " --bits 16"
    " --twopass"
    " --dither 1"
    " --pdf 1"
    " %s":SrcFileName
    " %s":DestFileName
    Yes, i'm a control freak!
  16. Get Slack disturbed1's Avatar
    Apr 2001
    init 4
    Should of thought to change that file.
    Here's another sample rate converter. Been a few years since I tried it out. I remember it being pretty decent though. Another tool to play with
    http://www.vlsi.fi/other/VS_SRC/#Package
    Some others I've tried but didn't really like
    http://www.voxengo.com/r8brain/
    http://www.harmony-central.com/Software/Windows/sound_file_converters.html (bunches of stuff)
    Have fun 8)
  17. see how that audio sounds and whether you can work around capturing it at 22. depending on what it is, it could sound anywhere from decent to just bad, even if you could upsample it.
  18. That AZZA-GUI is completely unavailable! The page doesn't exist anymore.
    Mar 2007
    Hi Everyone,
    I know this is one MAJOR bump i know but for anyone who drops in on the this post & would like to obtain a copy of AZZA-Gui I have found what is still a working link & here it is, grab a copy before it disapears for ever!
    http://afnm.netii.net/quick.html
    Scroll down the page and you will find it right click on it and save as viola you will have AZZA-Gui
    Regards & Best wishes,
    ispy
    Life is Like a Box of Chocolates.....
