  1. ddregs
    Guest
    Hi Major,
    the problem is a very strange one: using ffmpegx to create a DVD, 90% it works perfectly (same presets, DVD high bitrate, tmpgenc as Quality Matrix and Double Processor as Threading), it creates the m2v and mp2 then it stops with the usual error (I can't remember the exact phrase but it has a %d in the message error), I mux them manually and author as DVD.
    It plays on Mac but not on my DVD player. Not for all the movies I tried, and the media is the same (TDK DVD-RW), sometimes it playes sometimes not.
    What can be the problem? Any ideas? The DVD player is a Philips DVD-763SA.
    Thanx in advance
    Best regards
  2. ddregs
    Guest
    Just to expand: the dvd-rw just written is recognized by the DVD player as a DVD. But when I press the play button it just doesn't start.
    On my Mac (Superdrive DVR-103, 1.90 Firmware version) it plays smoothly.
    Any suggestions?
    Tks
  3. Try Sizzle to author, if it fails too then the problem is possibly with your DVD Player.
