A friend of mine ( Honest, it wasn't me ) wants me to burn a WMV file that he created to a VCD, but I'm having trouble converting the file to an MPEG1.
I can open the file in TMPGEnc fine, and it starts to encode, but when it hits 67% it freezes. I've tried this several times, and it locks up at the same percentage, and even the same exact frame every time.
I even paid $20 and downloaded DirectConvert but even it freezes up, I'm assuming at the same spot.
The file plays fine all the way through in Win Media Player, I just need it in another format to burn it to a disc.
Could this file just have a bad frame? If I snip out that spot, will I be able to convert it?
Any help would be appreciated!
BC
I have also opened this file in Windows Movie Maker and tried to re-save it, but it processes the file and seems to get almost two-thirds of the way through, then hangs.
I'm starting to think we're running out of options here. -
I've had pretty good luck with Canopus Procoder when converting windows media. You might not want to go through the trouble of downloading the trial version but I thought I'd throw it out there. Sorry things didn't work out.
Another thing I tried once was creating a fake avi with VFAPI Converter in conjunction with a TMPGEnc project file and then opening up the fake avi with Virtualdub. You might be able to delete the section that is causing the crashes this way. I ended up re-encoding to Divx and then converting it to VCD mpeg. Surprisingly I didn't lose much quality from the original wmv. This whole process probably sounds like a pain in the ass but it worked for me. Then again I like doing things the hard way sometimes. Gives me a greater sense of accomplishment I guess. :P
Help with converting from WMV to DV-AVI file..
By littlepipit in forum Newbie / General discussionsReplies: 2Last Post: 13th Feb 2009, 06:06 -
converting WMV file 408mb to DVD
By jbitakis in forum Authoring (DVD)Replies: 14Last Post: 31st Oct 2008, 07:31 -
Problem converting .wmv file
By AdamUK in forum MacReplies: 3Last Post: 24th Apr 2008, 07:40 -
Converting (Quicktime) .MOV file to .WMV file
By stanislawski in forum Video ConversionReplies: 2Last Post: 6th Feb 2008, 18:19 -
Converting an ASF (WMV) file
By yadda in forum Newbie / General discussionsReplies: 1Last Post: 7th Nov 2007, 06:16
