I downloaded an old tv series as avi files. I have converted them to mpeg using TMPENG. Reauthored them using DMPENG author to make a full DVD's worth. The mpeg are vcd quality to fit the entire series onto on DVD. The output from DMPENG author can't be read by dvdshrink nor dvddecryper to write to DVD, saying the vobs can't be decrypted:reason unknown. I tried infoedit and vobedit but not really sure how to use them. Do you guys have any ideas? Thanks
did you make an iso with tmpgenc dvd author? or an dvd video folder?
I have experienced the same problem with TMPGEnc DVD Author when creating the VIDEO_TS folder and the only workaround I have is to rip using Smartripper.
If in doubt, Google it. -
thanks for the help but it sorta solved itself, used the dvd writer in TMPEGnc Author. Logical really !
How to decrypt and copy CPRM .VRO files
By cprm_buster in forum User guidesReplies: 64Last Post: 3rd Oct 2023, 20:29 -
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 15:12 -
Editing .mov files and .ifo/.vob files
By redhot in forum EditingReplies: 7Last Post: 25th Nov 2008, 07:31 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 19:10 -
Converting PAL VOB FILES TO NTSC VOB FILES...
By mmmipa in forum Video ConversionReplies: 3Last Post: 5th Apr 2008, 17:15
