Hi to all up to date people........I'm from the old school I suppose when it comes to DVD-R burner programs.
Have always used my trusted Prassi Primo for burning DVD-R's for a long time now...................alas due to new writer (Pioneer 107) I need a more modern burner program.
What's everyone using these days for problem free burning??
Thanks for the advice (I say in advance of information)
KB![]()
Results 1 to 20 of 20
Nero. Nero Ultra Version 6 is nice but because of incompatibility with my firewire enclosure I have to use ver. 5.5.9.0 of the Nero Burning Rom application. That's probably one of the more popular apps around. Nero's solid and doesn't usually make coasters unless something is really wrong. It's a good app.
I agree with last post. I use Nero 6 Ultra Edition ,and I've never had a problem with it.
DVD Decrypter 3190 for copying DVD5 or DVDR/W
Nero (Express) 6303 or RNM (px507) for burning VIDEO_TS -
If I use DVD Shrink,I use the Nero6.0 engine.
If I author my own dvd's from mpeg I use the engine that comes with TMPEGEnc Author(By far my Fav Dvd author program takes any mpeg thrown at it,and makes better menus than pro ones).
The Nero Vision Express is garbage(didn't like any of my mpegs). -
If I made my living with a burning program there would be no way I would even look at anything but Nero. Some of the other burning programs are excellent, like Record Now etc. but, tend to lag behind in there recognition updates.
I have used Nero ( 5 & 6 ) for the past few years and have never had to wait for new updates so that my drives would work. I have 3 of them and Nero works great with them all. 2 Pioneers A05 and A06, and a Ricoh 5120 +RW.
Also use good media instead of the cheap stuff. Don't use the most expensive either. Ritek works great for me.
Have used Record Now Max and was also a good program but you can't have both on the same computer, so, I opted for Nero 6 and never looked back. -
Originally Posted by candsh
Im waiting for someone to say 'Nero is shit....and caused my wife to leave me and my house then burnt down, blah, etc'
'Nero is shit....and caused my wife to leave me and my house then burnt down, it even killed my Dog.
Just kidding when it comes to DVD backups i really dont know what im doing but even I can use nero (its that easy) and i have never had 1 single problem from it...
easy to use and does what it is supposed to do and does it well.The Reason that the grass is always greener on the other side of the fence is because thats where i bury the bodies ;) -
Interesting aray of repies.....''
Well firstly,
I may be completely wrong but I was led to believe in the beginning never never use Nero for burning DVD-R VIDEO_TS Folders. Great for cd-r but thats where it ends. Bloody hell this relates to older versions clearly as everyone seems to have great success with it. However I have never used it.
What you say is true then maybe I should consider using this (I have it already like most people).
My computer is fairly new and up to date running windows XP.
DVD Lab I actually use now to author my DVD's already so I may actually go with it on DVD burning unless there is a good reason why not?
However for replies with regard to this, Thanks a plenty....''
Nero is shit....and caused my wife to leave me and my house then burnt down, it even killed my Dog and my budgies flew away
and as monty python would say.. "and now for something completely serious.."
Nero 6.0.0.19 works wonders for me
but not the newer versions -
Originally Posted by indolikaa
My top 3 (in no particular order)
Nero
Dvd Decrypter
Stomp Record Now Max -
NERO IS Great but finnicky
if you have problems burning with 6.3xx
go back to 5.9xx if you can rather than spending the futile time trying to figure out the special reason why nero 6 is screwing up...
also from experience, if neither works for your system RECORD NOW MAX
is the obvious choice
so rather than tearing the hair out tring to fix the elusive mystery of ASPI
XP and USB and FIREWIRE connectivity issues.. I just find "one of the good programs that burn" and get it working on that system
this is not to deny the use of those other fave programs that can only handle one of the tasks ...eg SHRINK, DECRYPTER, and the like
Prassi was rock steady I will agree..but isn't updated
ANYONE TRY EASY MEDIA CREATOR 7?
just joking as this roxio has struck out 2x with 5.0 and 6.0 not doing dvd burning any service -
For single layer discs I use DVD Decrypter to make an iso of the disc.
For movies with Full Screen and Widescreen I use Nero Recode with AnyDVD to remove the Full Screen version. This way all menus are intact.
If I just want the bloody movie I use Shrink to reauthor the disc (and I usually just keep DTS track, if I can fit dolby digital without sacrificing space then I'll throw that in).
Thats all I really use. Been working for me since I got my burner. -
Originally Posted by hardcoreruss
Originally Posted by andydd
New DVD Burner
By pepegot1 in forum DVD & Blu-ray WritersReplies: 11Last Post: 22nd Feb 2010, 23:57 -
MKV to AVI program, hardsubbing program, adding subtitle to DVD Flick
By projecttemp in forum Video ConversionReplies: 1Last Post: 21st Sep 2009, 08:42 -
DVD video burner program
By karebo in forum DVD RippingReplies: 3Last Post: 21st Sep 2008, 04:19 -
What DVD Burner Do You Use?
By Ray&Paula in forum DVD & Blu-ray WritersReplies: 6Last Post: 20th Mar 2008, 01:01 -
IDE DVD Burner VS SATA DVD Burner
By mn072065 in forum DVD & Blu-ray WritersReplies: 13Last Post: 13th Nov 2007, 20:15
