  1. I have been cracking my head with TSCV for a long time and finally got it to work with chapters and menu for my VCD's.
    Great piece of software!
    There is one thing that i can't figure out, why does it always play a very small part of the 1st chapter when i jump between different chapters.
    It does this when i use the # pad to jump back or forward or the next and previous buttons. It always plays a very small part of the first chapter.
    Any ideas????.
    By the way i am in asia and in every home here, there is bound to be a VCD 2.0 compliant player. I have tested this on my JVC and Pioneer players they do the same.
  2. http://www.personal.psu.edu/users/r/d/rdm186/
    if you follow that guide, make sure that you have the same settings that are displayed there under your settings tab...make sure all your loop times are ok and everything else..you may want to go and get the updated tscv .74 rel 2 that just came out...go to http://www.ttool.de there is discussion on their forum where to get it
    try it, lemme know
  3. I did some tests and and i found that even when i just use VCDIMAGER EASY (with vcdimager 7.10) and create some chapters, the problem appears. It looks like no fault of TSCV.
    When i jump between chapters it always plays the chapter 1 (m1-0) for about 1 sec then jumps to the right entry point.
    I cant seem to counter this. I've followed all the help guides and i have learned a lot from them but it did not solve this problem.
    Any one else have this problem.
  4. http://www.personal.psu.edu/users/r/d/rdm186/regdrop.zip
    click on that, its mpg parser and decoder...you may have an overlay problem, intall them...if you already have..then i think i may be outta ideas
  5. I think you have a point here. I'll try that and see if it works. Will let you know later, I'm at work right now.
  6. The parser and decoder files are not there. Where can i get them?
  7. I found them.
