Hi,
Please help!
Best resolution to capture?
Best resolution and bitrate (min,average,max) to convert?
Cumps
Calitas
Hi roadster3043.
My capture card is a Asus Radeon 9600XT, my VHS player is a Sony SLV E-820 (I think that's the reference)
Greetings.
You need to verify if your card has any capture drivers compatible with VirtualDub, or if the card came with any capture software.
As for the VCR, I could'nt find any specs on the outputs that it has, so it need to be compatible with your card's inputs(S-VHS and Composite).--
Take Care.
JuanMa -
Hi there.
I just ask what resolution and what bitrate, don't worry whit my hardware.
I'm capturing whit Virtualdub, converting whit TMPGEnc, just wanna now what's the best resolution to use in Virtualdub, and best resolution and bitrate to use in the conversions on TMPGEnc.
Tu put the must minutes of video on a DVD whithout loosing quality.
tks
Calitas -
@ Calitas
Hi, as you're capturing from VHS (lower resolution when compared to SVCD, let alone DVD) you might want to check this out:
https://www.videohelp.com/forum/viewtopic.php?t=207014&highlight=
It's only an opinion based on what I know and have seen / read, but it may sow some seeds of interest... Good luck.
Originally Posted by roadster3043There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 09:21 -
How to convert a PAL VHS into NTSC VHS or DVD?
By coody in forum Video ConversionReplies: 9Last Post: 22nd May 2011, 02:09 -
VHS to DVD - LongPlay VHS Problem
By zanzi81 in forum Capturing and VCRReplies: 14Last Post: 1st Feb 2010, 01:56 -
VHS Copy Protection when using a Dual DVD\VHS Unit
By wizer in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2009, 14:25 -
NTSC VHS to PAL DVD Via DVD VHS Combi
By wozmac in forum DVD & Blu-ray RecordersReplies: 7Last Post: 6th Jun 2007, 01:16
