  1. Hello,
    I do not know if this possible but what I want to do is create a SVCD MPEG-2 and then burn it as SVCD file structure using DVD-R instead of CD Disc. The reason for this is CD holds very short movie i.e 40 minutes and hence have burn on multiple discs. Where as if I burn it on DVD-R it should fit the whole movie on one DVD-R.
    Thanks in advacnes.
    Apr 2002
    Ireland
    Have a look at the guides on this page for all the info you want:
    https://www.videohelp.com/author#3;29
    You can't burn as svcd(cd mode2) on dvd media. You can burn the svcd structure(just the folder structure) as data only on a dvd media but it wont work on most dvd players.
    Are you converting to svcd? if so just convert to dvd mpeg2 instead, you can use low resolutions(352x480/576) and low bitrates(~2000) similiar to svcd.
    If you have svcds movies that you want to put on dvd read boss link.
