  1. With DVD-Lab the menus have no very good quality (for example the text and the background image) when I play the menu on PC.
    Is there a setting to adjust the quality of the menus in DVD-Lab in order to have a good menu quality, like the commercial movie DVD have?
    Thanks a lot in advance.
    Simone Alessandrini
    Italy
  2. Member sacajaweeda's Avatar
    Sep 2003
    Would I lie?
    I use DVDLab and the menus I create with Photoshop look just awesome.
    Maybe the images you are using just suck to begin with?
    "There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
  3. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    I use DVD-Lab and love it. The only weekness it has is menu rendering quality. It likes to leave compression artifacts around text areas.
    There are a few thing you can try.
    1) You can add a little blur to the image before you import.
    2) Use Photoshop to make the menu and the text, then duplicate the text layer. Add a black stroke to the bottom layer and merge it with the background. Save as psd and import into DVD-Lab. Use the Hotspot Rectangle tool to select each text link. You can select highlight color you want.
    3) If you're still not happy with the quality, then make a motion menu with your image and text in a video editor and save as Mpeg. This will produce the best posible results if done correctly.
  4. I've used photoshop and done as much as I can in it. I save it as a .psd so i can make quick layer changes if needed once i see the finished menu. I asked this in my post, but do you have to use 72dpi images in your menu's or can you use 300?
    dlv
  5. Member racer-x's Avatar
    Mar 2003
    You can use 300 dpi if you want. I use 720 x 540 @ 150 dpi.
  6. awesome..maybe thats why my menu's looked so fuzzy and crappy
    dlv
  7. Member akbor75's Avatar
    Aug 2002
    Netherlands (Europe)
    dpi has no meaning when the picture stays on the screen. it's just a translation from real units (inches) to logical units (pixels).
    when i create a picture in adobe ps of 720x576 pixels, it will be the same quality no matter what dpi i use.
    of course when you use photos they should be of good quality. but as the tv resolution is relatively low, the dpi is not very important.
    Music was my first love, and it will be my last
