Hello,
could anyone tell me which is a good media brand for Toshiba 5112 DVD-R? I have bought Samsung DVD-Rs but although they are supposed to record 4x speed I cannot record more than 2x. Moreover I have a freezing problem on 2/3 of the movie. Could it be due to the disks I use? I backup and compress with dvdshrink and burn with nero 6.
thanks![]()
Update your firmware from here http://trtsoft.webzdarma.cz/toshiba/toshiba.htm (direct link http://trtsoft.webzdarma.cz/toshiba/SD-R5112-1033.zip)
I use Prodisc 4x media without any problems. -
I'm running Windows 2KPro, with the Toshiba as Secondary Master.
I just unzipped, ran the exe, read the instructions, clicked ok, reboot, flash, reboot, all is good
i got that burner and Ritek g04, Fuji,TDK and Sony have worked good for me..i havent had any problems with them freezing and no coasters yet except 1 memorex..
thanks namdekan,
but which software do you use for compression and recording? Yesterday I used DVD X Copy to record a SmartBuy brand DVD-R and the result was perfect. So the problem was either my Samsung DVD-Rs or the DVD Shrink + Nero 6 combination. I will do a few more tries with shrink+nero on disks other than Samsung to see what happens.
How good is the ATSC tuner in Toshiba DR570 DVD recorder ?
By SingSing in forum DVD & Blu-ray RecordersReplies: 11Last Post: 5th Apr 2010, 19:05 -
Toshiba DR410 DVD Recorder -- Any good?
By ministry88 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 24th Dec 2008, 16:41 -
Looking for DVD player replacement - Good DVDR media support? (~£50)
By John_Jordan in forum DVD & Blu-ray PlayersReplies: 1Last Post: 18th Mar 2008, 15:12 -
Toshiba DVD Drive does not recognize Philips DVD-R media
By garybeck in forum DVD & Blu-ray WritersReplies: 12Last Post: 5th Nov 2007, 13:57 -
Toshiba DVD players & -R media issues??
By videobruce in forum DVD & Blu-ray PlayersReplies: 8Last Post: 5th Nov 2007, 07:02
