Some of you may remember that I asked about a drive enclosure for my DVD recorder. I got a Firewire and USB 1.1/2.0 enclosure and it works great. To the real problem, I have an 80GB hard drive I want to use on my laptop
On the back of the DVD enclosure, there are two connectors for Firewire, one is connected to my laptop. If I get a firewire enclosure for the hard drive, can I simply connect the hard drive enclosure to the second Firewire connector on the DVD recorder and daisy chain the two together and it's all good?
I've had no problem daisy-chaining 2 external firewire drives. Worked quite nicely.
Yes, that's pretty much what that extra port is there for. I can't recall for sure but I think you can chain up to 32 FireWire devices. Or maybe it was 16. Either way that's a lot of devices.
On a related note, has anyone seen extra-deep FireWire enclosures? I'm looking for ones with maybe 10" of drive depth but just plain ATA/133 capable. -
AFAIK its 255 devices you can have daisy chained... Might be a bit much to have them all going at the same time.
Hex FF binary 11111111. trinary 100110Corned beef is now made to a higher standard than at any time in history.
What is Trinary? Never heard that.Originally Posted by RabidDog
I've only heard of:
Hexidecimal
Binary
Binary Coded Decimal
Octal
When it comes to basic computer language. -
here's some help on what Trinary (http://xyzzy.freeshell.org/trinary/) is, it's basically binary with a third choice, so to count in trinary is 0, 1, 2, 10, 11, 12, 20, 21, 22, 100, 101, 102, 110, etc...
anywho, thanks for the answer, I had a good idea but I wanted to be ultra-sure.
External HDD Enclosure Question
By Timex in forum ComputerReplies: 4Last Post: 1st Aug 2011, 13:53 -
sumvision cyclone mkv enclosure
By lulabell75 in forum Media Center PC / MediaCentersReplies: 4Last Post: 20th Jun 2010, 16:26 -
Hard Drive Enclosure Issue
By Frank-0-Video in forum ComputerReplies: 11Last Post: 26th Apr 2010, 17:47 -
External Harddrive Enclosure
By AuroEdge in forum ComputerReplies: 0Last Post: 3rd Jan 2010, 12:20 -
taking off dvd burner enclosure. Help
By dymx in forum DVD & Blu-ray WritersReplies: 10Last Post: 21st Jun 2008, 20:02
