I have some avi files that I want to send my son who has a MAC. I would like to convert the files to .mov so he can use them in iMovie on his MAC. Is there a free or relatively inexpensive conversion program to do this?
I use RAD Video Tools to go the other way from .mov to .avi and it works well.
I am just learning, so be patient with me and some of the questions I might ask.
Well, there's Canopus Procoder. Only problem is that it's quite far from being inexpensive. On the plus side however, there's a free trial version available. It should do the trick if you only need a temporary solution.
You know what? I almost forgot about MPEG-4 Direct Maker. I think the interface is terrible but it will convert your file to mp4 which will play in Quicktime. It's a heck of a lot cheaper than Canopus too($50 vs. $400).
or just use quicktime and export the file ..
the mac can also read dv avi"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
just tell your son to download Video Lan Player (www.videolan.org)
this is a free app that is a media player who can play almost any file you toss at it.
Its nice for divx etc becaue no codex required.
Converting wmv files to play in Quicktime
By gombik in forum Video ConversionReplies: 4Last Post: 3rd Sep 2009, 08:11 -
Problem converting quicktime .mov files to mpeg-1
By jtk in forum ffmpegX general discussionReplies: 8Last Post: 2nd Sep 2008, 18:42 -
Uncompressd AVI Files Out of Sync in Quicktime
By phild in forum Video ConversionReplies: 2Last Post: 17th Aug 2008, 13:05 -
trouble converting Quicktime mov. to avi (on windows XP)
By pifkel in forum Video ConversionReplies: 3Last Post: 31st Dec 2007, 04:19 -
Suggestion for converting hundreds of mov quicktime files
By m021478 in forum Video ConversionReplies: 0Last Post: 15th Aug 2007, 15:16
