Hey... Ive caputured in a wierd type of way. I caputured using my tv turner card. Ive got the file and i need a program that will convert it to avi or dvd formate. The file name is dvr-ms. I haven't found a program that can convert that type of file. If any of you can help me ill really appreciate it. Thanks for your time.
dvr-ms !! That could mean anything. What are you using to capture? What is the file name extension (avi,mpg, whatever)?
You have to give more information if you want help. -
Do any of the files on your pc display an .xxx extension?
e.g. filename.avi, filename.mpg, filename.wav to name but a few. -
I agree with feenix, It would help if we knew what hardware and software you were using.
I take it this is a Windows Media Center Edition PC. Those files are a Microsoft proprietary format designed to limit playback on the PC it was made on only. It does contain MPEG-2 video though and Microsoft has since released an update to let a user play the files on another of the users computers. I don't know what hoops you'll have to jump through to convert or make the file useable but you might want to start by digging around at microsoft.com to see what can be done with it.
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/directx9_c/directX/ht...dvrmsfiles.aspPB
Window Media Center Help
By vcd4me in forum Capturing and VCRReplies: 4Last Post: 14th May 2011, 17:18 -
Media Center
By superc in forum LinuxReplies: 4Last Post: 7th Jan 2011, 20:39 -
Capturing on Hp Media Center PC
By MuffinMaYne in forum Capturing and VCRReplies: 0Last Post: 28th Nov 2007, 12:18 -
Sharing TV - 1 Vista Media Center Server to Vista Media Center PC
By JBredensteiner in forum Media Center PC / MediaCentersReplies: 8Last Post: 14th Jul 2007, 02:33 -
Media Center Help
By rwheeler in forum Video ConversionReplies: 4Last Post: 25th Jun 2007, 14:06
