Results 1 to 12 of 12
  1. Just when I thought I was getting the hang of dvd burning (I've made about a dozen now) I've started getting this error message every time.
    I use Ulead Movie Factory 2 SE, and immediately after it says initializing dvd for recording, the drive ejects the dvd, and an error window pops up that says "Generic error from CD/DVD recording software. Please make sure the drive is ready and try again. Error: DVDR-DAO-SPTI-53-02-05-24-00." I've also gotten the same error when trying with a rw disk, but the number it give me is DVD+RW-SPTI-04-02-02-30-05
    I tried using Ulead Video Studio, but it gave me the same error after a much longer time. I think it does some rendering that Movie Factory does not. This program often freezes my computer so I don't use it except to capture stills from my videos for jewel case covers.
    I've tried different movies, and several different types of disks.
    I've gone to the Ulead site and downloaded the 2 patches they have for Movie Factory, but I get the same error.
    I've tried changing the recording speed to match the write strategy speed, as suggested on LordSmurf's website (I love that place!)
    I use ADS instant dvd, an external bridge, to copy vhs to my hard drive as mpg with an ADS program called capwiz. My burner is a Sony DVD RW DW-U50A. It's in my laptop.
    So I'm hoping someone has some ideas for me.
    Nancy
  2. Member dcsos's Avatar
    Jan 2003
    Y No Werk (anagram)
    OK.. I have a work around
    Will ULEAD MOVIE FACORY output a File/Folder Hierarchical structure?
    That is, can you build the DVD VOLUME to the Hard Drive Instead of the DVD SURFACE DIRECTLY?
    If so,
    The way to isolate whether the problem is with:
    1 The OS and the burner
    2. Ulead and the Burner
    3. Ulead and the OS
    is to output the project to hard drive, then using another program entirely
    NERO would by my choice
    BURN the DVD thusly,
    AT LEAST YOU OUTTA GET A DIFFERENT ERROR MESSAGE!!!!
  3. Member dcsos's Avatar
    Jan 2003
    Y No Werk (anagram)
    OK a searchon this site on Disc At Once(DAO) errors shows another user of the SONY
    Burner found that DISABLING DMA mode and setting it to PIO in the device manager fixed a DAO error message similar to your'n
    So under the properties of the IDE CHANNEL to which the burner device is attached (not easy to find because windows doesn't actually say what device is attached where in WIN XP, im afraid)you change from ULTRA DMA mode to simple PIO mode..
    Hope you don't have to do this though-- as it will decrease slightly the burn speeds you achieve
    ALSO PLEASE UPDATE YOUR ASPI LAYER AND TRY AGAIN..the error message you had shows your system is accesing the BURNER without ASPI access.. this could be ok...
    but could be the source of the problem ..the correct drivers are here
    http://www.adaptec.com/worldwide/support/driverdetail.html?sess=no&language=English+US...aspi_471a2.exe
    you should just download them and install them and reboot and retry before you do the other more complex fix I suggested above
  4. Yes....https://www.videohelp.com/forum/viewtopic.php?t=206699
    Everyone needs to update this file, but it does take someone who knows computers to load it; or simply read very carefully.
    Cheers
  5. Thanks guys. Last night I tried updating the ASPI drivers to no avail. The ulead site suggested also disabling write caching on the disk which I did. Tonight I'll try changing dma to pio and see how she goes. I have that setting in four places. Primary IDE channel, Device 0 and Device 1 and Secondary IDE channdel, Device 0 and Device 1. So I'm going to change all four, and give her a go.
  6. Originally Posted by warriorprincess
    Did you try getting DVDMF to just create the DVD directories and burning with another program like Nero? This is what I do mostly all the time since I usually want to save the directory structure on the HD for reuse later without having to reauthor (burn on a DVD+RW to check, then later to a DVD+R)
  7. Originally Posted by warriorprincess
    Nancy
    It's possible since you have burned ok, that a cleanup might work? CleanDisk & Defrag....Just a thought.
    It takes some concentration to actually load the ASPI driver, if one is not 'intimate' with how these files install...Could I suggest opening Notepad, cut & paste the instructions, have the method open as you do it.
    Still think trying a cleanup first might work for you -Often XP will state it does not need a defrag...But does.
    Cheers
  8. Member dcsos's Avatar
    Jan 2003
    Y No Werk (anagram)
    What I do is after install I run NERO INFO CHECK
    it says if aspi went in ok!
  9. I tried changing to PIO, and still got the same error. So I encoded them to disk, and tried burning, same error. Then I installed Nero and tried to burn. This is nice software. The error here clearly indicated the media was bad. I thought I had ruled this out, since I had gone through several in the 2 new packages and they all failed, where I had used the exact same brand, Memorex, before with no failures.
    These are expensive disks, since I'm learning, I thought packs of 6 R/W disks would be the best way to go until I learn what works. But I've only had 2 successes out of 8 attempts. I thought I'd be able to reformat R/W but I guess when it's bad, it's bad, it doesn't matter if it's R/W or not.
    I changed back to DMA by the way.
    I greatly appreciate the help. Thank you all.
    Nancy
    Btw, here's the error log from Nero for those who are interested:
    Nancy
    1502-4240-1202-0757-1131-9785
    Windows XP 5.1
    IA32
    WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 7/17/2002 10:03:20 AM
    ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 1/29/2003 3:37:36 PM
    Nero Version: 5.5.10.53 (Nero Express)
    Recorder: <SONY DVD RW DW-U50A> Version: 1.5a - HA 1 TA 0 - 5.5.10.53
    Adapter driver: <atapi> HA 1
    Drive buffer : 8192kB
    Bus Type : default (0) -> ATAPI, detected: ATAPI
    CD-ROM: <SONY DVD RW DW-U50A> Version: 1.5a - HA 1 TA 0 - 5.5.10.53
    === Scsi-Device-Map ===
    DiskPeripheral : HITACHI_DK23EA-60 atapi Port 0 ID 0 DMA: On
    CdRomPeripheral : SONY DVD RW DW-U50A atapi Port 1 ID 0 DMA: On
    AutoRun : 1
    Excluded drive IDs:
    CmdQueuing : 1
    CmdNotification: 2
    WriteBufferSize: 74448896 (0) Byte
    ShowDrvBufStat : 0
    EraseSpeed : 0
    BUFE : 0
    Physical memory : 510MB (523244kB)
    Free physical memory: 271MB (277808kB)
    Memory in use : 46 %
    Uncached PFiles: 0x0
    Use Static Write Speed Table: 0
    Use Inquiry : 1
    Global Bus Type: default (0)
    Check supported media : Enabled (1)
    Wizard: On
    20.2.2004
    UDF/ISO compilation
    2:27:39 PM #1 Phase 112 File dlgbrnst.cpp, Line 1655
    DVD-Video files reallocation started
    2:27:39 PM #2 Phase 114 File dlgbrnst.cpp, Line 1655
    DVD-Video files reallocation completed (no file modified)
    2:27:39 PM #3 Text 0 File Isodoc.cpp, Line 7604
    Iso document burn settings
    Determine maximum speed : FALSE
    Simulate : FALSE
    Write : TRUE
    Finalize CD : TRUE
    Multisession : FALSE
    Burning mode : DAO
    Mode : 1
    ISO Level : 1 (Max. of 11 = 8 + 3 char)
    Character set : ISO 9660
    Joliet : TRUE
    Allow pathdepth more than 8 directories : FALSE
    Allow more than 255 characters in path : FALSE
    Write ISO9660 ;1 file extensions : TRUE
    2:27:39 PM #4 Phase 111 File dlgbrnst.cpp, Line 1655
    DVD-Video files sorted
    2:27:40 PM #5 Text 0 File Reader.cpp, Line 115
    Reader running
    2:27:40 PM #6 ISO9660GEN -11 File geniso.cpp, Line 4571
    First writeable address = 0 (0x00000000)
    2:27:40 PM #7 ISO9660GEN -11 File geniso.cpp, Line 4571
    2:27:40 PM #8 Text 0 File Burncd.cpp, Line 3768
    Turn on Disc-At-Once, using DVD media
    2:27:40 PM #9 Text 0 File ThreadedTransferInterface.cpp, Line 672
    Setup items (original item values)
    0: TRM_DATA_MODE1 (CTransferItem)
    2 indices, index0 (150) not provided
    original CD pos #0 + 1988448 (1988448) = #1988448/441:52.48
    relocatable, CD pos for caching/writing not required/required, no patch infos
    1: TRM_DATA_MODE1 (CTransferItem)
    2 indices, index0 (0) not provided
    original CD pos #0 + 1 (1) = #1/0:0.1
    relocatable, CD pos for caching/writing not required/not required, no patch infos
    2:27:42 PM #10 Text 0 File DlgWaitCD.cpp, Line 229
    Last possible write address on media: 2295103 (510:01.28)
    Last address to be written: 1988448 (441:52.48)
    2:27:42 PM #11 Text 0 File DlgWaitCD.cpp, Line 234
    Write in overburning mode: FALSE
    2:27:42 PM #12 Text 0 File DlgWaitCD.cpp, Line 1694
    Recorder: SONY DVD RW DW-U50A, Media type: DVD+RW
    Disc Manufacturer ID: RICOHJPN, Media Type ID: W11, Product revision number: 1
    Disc Application Code: 0, Extended Information Indicators: 1
    2:27:43 PM #13 Text 0 File ThreadedTransferInterface.cpp, Line 824
    Prepare recorder SONY DVD RW DW-U50A for write in cue-sheet-DAO
    DAO infos:
    MCN:
    TOCTYPE: 0x0 Session Closed, CD fixated
    Tracks 1 to 2:
    TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 -222318592
    TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos -222318592 -222318592 -222316544
    2:27:43 PM #14 Text 0 File ThreadedTransferInterface.cpp, Line 672
    Setup items (after recorder preparation)
    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1988448 blocks [SONY DVD RW DW-U50A ]
    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1 blocks [SONY DVD RW DW-U50A ]
    2:27:43 PM #15 Phase 24 File dlgbrnst.cpp, Line 1655
    Caching of files started
    2:27:43 PM #16 Phase 25 File dlgbrnst.cpp, Line 1655
    Caching of files completed
    2:27:43 PM #17 Phase 36 File dlgbrnst.cpp, Line 1655
    Burn process started at 2.4x (3,312 KB/s)
    2:27:43 PM #18 Text 0 File ThreadedTransferInterface.cpp, Line 1978
    Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
    2:27:43 PM #19 Text 0 File ThreadedTransferInterface.cpp, Line 1978
    Verifying CD position of item 1 (relocatable, no CD pos, no patch infos, orig at #0): write at #0
    2:27:43 PM #20 Text 0 File Cdrdrv.cpp, Line 7931
    ---- DVD Structure: Physical Format Information (00h) ----
    Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
    Book Type: DVD+RW (9), Part Version: 2
    Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
    Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: re-writable
    Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
    Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
    End Physical Sector Number of Data Area: 26053F h
    End Sector Number in Layer 0: 0 h
    Data in Burst Cutting Area (BCA) does not exist
    Media Specific:
    00 01 52 49 43 4F 48 4A - 50 4E 57 31 31 01 39 23 ..RICOHJPNW11.9#
    00 8A 86 68 02 26 00 8A - 86 70 02 28 00 8A 86 6A ...h.&...p.(...j
    02 28 22 12 10 E0 00 F0 - 00 00 00 00 00 00 00 01 .(".............
    2:27:43 PM #21 Phase 98 File dlgbrnst.cpp, Line 1655
    Start formatting media before burning
    2:27:43 PM #22 SCSI -1046 File Cdrdrv.cpp, Line 1241
    SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x0012CE70
    Status: 0x04 (0x01, SCSI_ERR)
    HA-Status 0x00 (0x00, OK)
    TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
    Sense Key: 0x02 (KEY_NOT_READY)
    Sense Code: 0x30
    Sense Qual: 0x05
    CDB Data: 0x04 0x11 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    Sense Data: 0x70 0x00 0x02 0x00 0x00 0x00 0x00 0x12
    0x00 0x00 0x00 0x00 0x30 0x05
    2:27:45 PM #23 Phase 101 File dlgbrnst.cpp, Line 1655
    Formatting media failed
    2:27:45 PM #24 Text 0 File DVDPlusRW.cpp, Line 463
    Start write address at LBA 0
    DVD high compatibility mode: Yes
    2:27:45 PM #25 DVDR -1046 File ThreadedTransferInterface.cpp, Line 1423
    Illegal medium
    2:27:45 PM #26 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1423
    Could not perform start of Disc-At-Once
    2:27:45 PM #27 Phase 38 File dlgbrnst.cpp, Line 1655
    Burn process failed at 2.4x (3,312 KB/s)
    2:27:45 PM #28 Text 0 File Scsicmd.cpp, Line 406
    SCSI not using temporary buffers
    20 out of 20 temporary buffers allocated
    Existing drivers:
    File 'Drivers\ASPI32.SYS': Ver=4.71 (0002) built by: WinDDK, size=16512 bytes, created 7/17/2002 9:05:10 AM
    File 'Drivers\PXHELP20.SYS': Ver=2.02.42a, size=17184 bytes, created 10/21/2002 12:33:40 PM (Prassi/Veritas driver for win 2K)
    File 'Drivers\atapi.sys': Ver=5.1.2600.1106 (xpsp1.020828-1920), size=86912 bytes, created 8/29/2002 7:00:00 AM (Adapter driver for rec)
    Registry Keys:
    HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
  10. Member dcsos's Avatar
    Jan 2003
    Y No Werk (anagram)
    you should be able to..just look on the menu in nero for a format
    r/w and do it using the full erase (takes just as long as writing a 1mb file and finalizing would)
    and MEMOREX aint the best
    try tdk's or even comp usa's own 1x with that sony
  11. When I try to do a full erase, it tells me illegal medium.
  12. Member dcsos's Avatar
    Jan 2003
    Y No Werk (anagram)
    Look at this from EMI TEC site (a DVD blank maker)
    EMTEC DVDs always completely fulfill the technical standards and quality demands of the DVD Forum resp. The DVD + Alliance. Despite this, caused by the ongoing development mentioned before, is it possible that the very latest stage of development cannot yet be handeled by the DVD writer, because the relevant Data for aligning correctly is not yet in the firmware. Simply said, your DVD writer got no Idea how to write on this specific DVD. As a result, there may be write failures or the disk is not even accepted (illegal media).
    How to cure compatibility problems
    Compatibility problems can easily be cured by a firmware update of the DVD writer. This way, the writer "learns" your writer how to handle new, yet unknown media. Due to this, manufacturers of DVD writers release firmware updates on their homepages in regular intervals, containing more media.
    http://www.emtec-webassistance.com/en/Cd/Dvd_Firmware_Update/
