I'm trying to burn a 580MB SVCD with Nero 6. When it gets done encoding it tries to burn but gives an error saying the disc does not have enough free space? WTF? It's a 700MB Imation CD-R. What could be wrong?
Thanks for any help.
I'm guessing that the filesize is 580MB before encoding ?
What I think is happening is that your source file is 580MB but when Nero encodes it to SVCD the file is much bigger.
It is not a good idea to use Nero to encode your SVCDs or VCDs for you. You would be better off using TMPGEnc or something like that because Nero is known to be a bit suspect.If in doubt, Google it. -
If you had an SVCD file then nero would not need to do any encoding! Your file obviously is not SVCD, check it with avicodec to get the file info and click on "What is SVCD" in the blue section over there <-<-<-.Originally Posted by kingkill33"Art is making something out of nothing and selling it." - Frank Zappa
Good burner, crappy encoder.Originally Posted by jimmalenko
Problem with target filesize in xvid
By legion0 in forum Video ConversionReplies: 18Last Post: 22nd Mar 2010, 00:58 -
Reducing Filesize of .avi
By jonesb in forum Newbie / General discussionsReplies: 5Last Post: 4th May 2009, 12:01 -
Reduce VOB filesize
By jacktorrance in forum Video ConversionReplies: 8Last Post: 14th Jan 2009, 12:34 -
MKV => AVCHD (determining the filesize HELP!)
By likwid8 in forum Authoring (Blu-ray)Replies: 4Last Post: 6th Jan 2009, 12:17 -
Reducing filesize
By caper in forum Video ConversionReplies: 19Last Post: 7th Dec 2008, 20:22
