I followed this guide exactly:
http://www.doom9.org/index.html?/capture/start.html
Using VirtualVCR for capturing, and VirtualDub for processing. The only times I strayed from the guide was using a newer version of DivX and a different deinterlace filter.
Anyway, I have two strange problem. The audio lags about 10 seconds behind the video. In addition, the voices in the video are consideably lower pitched than they should be. What did I do wrong?
EDIT: Well, that's weird, my original AVI capture is fine, but when I open up VirtualDub and cut out the commercials, the new AVI file has out-of-synch audio. I tried with a fresh VirtualDub install, cut out the commercials, and then saved as AVI. What am I doing wrong?
I'm not having the freezing video frames as described in that guide. Or would the solution to that problem also help mine?
Regardless of why you had to remove the frames, the guide should keep your audio in synch. That is what you want, right?
Hello. -
Argh, my fault. I extracted the WAV from the original file and it's audio was pitched low. So the original caputre is screwed up. I wonder what went wrong, I configured VirtualVCR exactly as the guide described. I'll go check over it again.
My first attempt to backup a DVD failed...
By Inkognito in forum Newbie / General discussionsReplies: 1Last Post: 8th May 2010, 18:07 -
Problems with BD Rebuilder: failed attempt to multiplex
By ajhansen91 in forum Blu-ray RippingReplies: 6Last Post: 23rd Apr 2009, 10:06 -
PC shutsdown when I attempt to burn DVD
By steve1040 in forum ComputerReplies: 2Last Post: 21st Oct 2008, 10:10 -
pc only boots on second attempt
By bassbinn in forum ComputerReplies: 6Last Post: 2nd Nov 2007, 15:37 -
My First Attempt at Video Editing (using Sony S/W)... my problems!
By iainw in forum Newbie / General discussionsReplies: 10Last Post: 14th May 2007, 04:58
