Hello:
Can someone please help! I am trying to convert an avi file to mpeg but I am not able to preview in tmpgenc the video and when I encode the file to mpeg I only get sound no video. I just downloaded the recent version 2.0 of tmpgenc with the vfapi plug in. Please let me know what I am doing wrong and how I can fix it.
Thanks,
pibe
Your avi is probably encoded using a codec that is not installed on your machine. Try installing the Divx codec and see if it helps.
Cheers -
Hello Aguillon:
I downloaded the divx4 codec and It still doesn't work. What should I do.
Thanks,
Pibe -
Use a template for which you have a decoder. Most likely you are converting to MPEG-2 and have no
decoder for that. Use the Video CD template, which generated MPEG-1, and you'll be able to see the
video on your PC.
AVI-video very choppy in preview but smooth in trimmer
By JackDalton in forum EditingReplies: 3Last Post: 28th Nov 2010, 20:21 -
PROBLEM: AVI -> MPG by using TMPGEnc 4.0 XPRess (4.2.3.193)
By Hummelchen in forum Video ConversionReplies: 0Last Post: 14th Jun 2010, 07:10 -
No audio in preview or output MPG file in VOB2MPG 2.0
By scruzphreak in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 16th Jul 2009, 13:20 -
File size problem with TMPGEnc [.avi to .mpg conversion]
By Timex in forum Video ConversionReplies: 7Last Post: 26th Jun 2007, 22:50 -
TMPGEnc not working.. what else is good for avi to mpg?
By andre477 in forum Video ConversionReplies: 10Last Post: 21st May 2007, 02:52
