hey ok well i had a similar problem with using cdrwin but thats fixed but now when i go to "record disk" mind u im trying to burn a cue file now this error comes up...
Error: 'WRITE' command failed on device 1:1:0
Illegal command request (04h 00h 02h 05h 10h 02h)
so now im stuck! some help would be greatly appreciated!!
Use nero to burn the image file,choose file/burn image and browse for the cue file and start burning.
i burned the cue file all put it into my dvd drive and just the contents come up like empty folders no VIDEO
If nothing burned then somethings wrong with the bin file,nero will automatically burn the bin file cause when it loads the cue file it knows to burn the bin file,the cue file is the instruction sheet for how to burn the bin file,are you sure you used the burn image option in nero and not just drag the file over?
Make sure u have chose the correct writer and make sure u choose CD and NOT DVD. Thats ur problem. Select BURN IMAGE
