Hi
I have an *.mpg file that I would like to convert to *.avi.
The problem is that when I convert to *.avi with VirtualDub MPEG2 and then go see the movie, the sound is like 3 seconds ahead.. But when I play the original *.mpg file the sound is good. What options do I have to use in the Audio Tab?
Is there any other program to convert from *.mpg to *.avi?
Is it a problem with the original file?
*humpf*
Thanks,
Tiago.
Did the original MPEG file play right (in sync) in VirtualDub MPEG2 before conversion. If it didn't then you need to adjust Interleaving 'Audio Skew Correction' to get it right (in snyc) before saving as an AVI. This should fix your problem.
Good luck. -
yes, that's it.. in virtualdub mpeg2 it doesn't play the sound correctly.. I'll try that now. thanks.
MPEG2 to AVI or whatever VirtualDub will use
By bpatters69 in forum Video ConversionReplies: 4Last Post: 1st Nov 2009, 19:19 -
Virtualdub-MPEG2 - DV-AVI Video Codec For Widescreen
By minko in forum Video ConversionReplies: 16Last Post: 10th Nov 2008, 01:49 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 17:08 -
Problem with Virtualdub-MPEG2
By deepakOne in forum Video ConversionReplies: 2Last Post: 5th Oct 2007, 02:35 -
Please Help! Can't Get VirtualDub-MPEG2 file size down!
By dano187 in forum DVD RippingReplies: 2Last Post: 26th Jun 2007, 19:15
