  1. I have Adobe Premeire, and I just got a filter for it called AGEDFILM, but how do I add filters in Premeire?
  2. Member ashtones's Avatar
    Aug 2001
    First highlight the clip on the timeline you want the effect for then in your video options fing the clip and drag it onto the clip. This should open up a dialouge box where you can alter the settings of the filter.
