Unable to download an appropriate decompressor. (Error=80040200) i get this msg when i try 2 play a avi file in media player i got g spot and it thinks everything is fine but still get that error it says the codec is iv41 Indeo Interactive and the audio PCM Audio which says on stat says no codec required is there any codec i can download 2 make this work
u need indio video codec, but if u have it, make sure its installed. Open vdub and check your codecs and see if its there. If not then find it on ur pc and instal it or google it and d/l and instal it.
I had a similar problem with Indeo RT21. I couldn't find a version that would work with NT so i wondered if a later version could decode it.
It worked like a charm. I just added the line "vidc.RT21=ir32_32.dll" to the registry. It now reads the (FOURCC) of "RT21" with the library that usually reads (FOURCC) IV32.
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Drivers32]
"vidc.iv32"="ir32_32.dll"
"vidc.RT21"="ir32_32.dll"
You could try something similar, and if it doesn't work, just delete it.
CODEC problem
By DavidPriest in forum Newbie / General discussionsReplies: 2Last Post: 10th Jul 2011, 06:39 -
CamStudio codec problem
By terrypin in forum Newbie / General discussionsReplies: 1Last Post: 5th Mar 2008, 16:17 -
I think I have a codec problem. D:
By Neverwhere in forum Newbie / General discussionsReplies: 6Last Post: 24th Jan 2008, 16:02 -
WMV codec problem
By coasterfreak212 in forum Portable VideoReplies: 7Last Post: 24th Jan 2008, 11:34 -
codec problem...
By cwb in forum EditingReplies: 6Last Post: 16th May 2007, 11:29
