I'm trying to do a PAL -> NTSC conversion. The original file is more or less VCD standard (VCD video with DVD sound). The orginal PAL file is 01:43x (hh:mm
s). When I do the conversion (using TMPGEnc v2.521.58.169) the NTSC file is 00:54:49. That's a 60+ minute difference.
I've tried various combinations of settings in TMPGEnc (3:2 pulldown, inverse 3:2 pulldown, inverse telecine, etc) and it doesn't seem to make a difference. The last PAL -> NTSC conversion I did, did NOT require any of these settings and it came out fine. So I'm really puzzled. I've read the guides on this board but I get the same result.
Any ideas what I'm doing wrong??
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 21:43 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 11:34
x (hh:mm
