I live in Sydney (PAL) and I have family in the US (NTSC). I visited them a month ago and am in the process of making a slideshow of digital pictures taken over there and adding short video clips taken from the digital camera on DVD using Ulead's DVD PictureShow v2.
Do I have to worry about what tv system I do it on?
Results 1 to 12 of 12
unfortunately yes, a lot of north american hardware cannot display a pal signal correctly
Thanks Craig
So my option is to do the one project but outputing one on PAL (for myself) and another NTSC via the preference option?
Rgds
Patrick -
That would be advisable, yes.
Many Thanks Craig,
Oh, while I still have you...
Not sure if you're familiar with Ulead's dvd pictureshow, but the short videos taken by my digital camera are in avi format. Using Pictureshow, will the program auto convert the avi to mpg2 if burn to dvd?
Thanks Again.
Rgds
Patrick -
Originally Posted by Souwalker
Many Thanks
Will try and see how quality is.
Thanks Again Craig
Rgds
pat -
Doesn't most PAL hardware play NTSC also? If yours does, you may be able to get away doing just the one in NTSC.
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
Originally Posted by sacajaweeda
Thanks Again.
Pat -
The only problem is that the NTSC disc will be poorer quality than the PAL one due to lower resolution (you will loose 1/5 of your picture), so making two seperate discs might be a better bet.
Originally Posted by energy80s
Rgds
Pat -
Well, you would be encoding your stills as video anyway, so yes, there will be a deteriation in picture quality between PAL and NTSC.
Question why these high dollar BluRay players are not multi-system
By jimdagys in forum DVD & Blu-ray PlayersReplies: 3Last Post: 6th Apr 2010, 10:18 -
Question about home theater system (Audio)
By jtrinc in forum AudioReplies: 37Last Post: 9th Jul 2009, 19:51 -
question about PC running hot -room humidity and water coolance system
By mazinz in forum ComputerReplies: 7Last Post: 29th Apr 2009, 17:27 -
System Restore - SP3 update question
By SCDVD in forum ComputerReplies: 6Last Post: 10th May 2008, 01:38 -
question about disappearing "hide protected operating system files
By jimdagys in forum ComputerReplies: 3Last Post: 8th Apr 2008, 19:24
