I have a Dell 2.8 GHz Pentium with HT and 512 MB of RAM. Right now I am using integrated graphics. I am considering buying an AGP card to improve performance for video editing and authoring. Does anyone have any recommendations for the minimum specifications that I need? I don't plan to do any gaming, just video.
A video card will not - improve performance for video editing and authoring as such.
For convience of MPEG2 capture look at the ATi AIW radeon series.
For high quality 2D multi monitor capable cards, look at the Matrox dual head series of cards.
64Mb is more than enough . You do not need more for 2D video work.
Multi monitor (or s video to TV) is an asset.
Ensure your motherboard onboard video can be disabled. Since it already has an AGP slot it would appear so.......but you never can tell with dell.
I'd say get a minimum 64mb of DDR VRAM. Just so you know, a new graphics card probably won't help editing and authoring performance. Those 2 things are CPU and RAM dependant. However if you want to do analog capturing, a new card that has capturing abilities like an ATI All-In-Wonder would be a good investment.
Thanks for the quick response.
While I was inserting chapter points in TMPGenc, I was noticing a delay in the frame-by-frame display view when I was scrolling through footage. I was thinking that a dedicated graphics board would improve/fix this, but it sounds like I should not expect it to. It sounds like I should probably save my money since I don't need a capture board right now (though I might go this route in the future).
Need another graphics card already!
By A Traveller in forum ComputerReplies: 15Last Post: 26th Sep 2011, 17:07 -
Very Weird issue with Capture Card and Graphics Card? Please help
By Ps3riiper in forum ComputerReplies: 9Last Post: 11th May 2011, 16:51 -
Need Graphics Card Recommendation
By mysts in forum ComputerReplies: 4Last Post: 15th Mar 2008, 19:52 -
need a new graphics card..
By SE14man in forum Newbie / General discussionsReplies: 11Last Post: 28th Dec 2007, 02:50 -
What sort of Graphics Card/Capture Card to get
By Dr_trout in forum Capturing and VCRReplies: 4Last Post: 24th Jul 2007, 16:19
