Anybody managed to get this DVD writer working with -R Media
having a nightmare it will only work +media
Spent 40 quid on media and it just chucks it out.
I have upgraded to the latest firmware.
Paul
It's a rebadged Optorite DD401. I have the Opto, but never tried with -R. I mention all this because some rebadged drives can take OTHER brands' firmware. I don't know if the newest Opto firmware will work in your drive, or if it will help your problem. Just thought I'd mention it.
I purchased this drive 2 weeks ago and burned 3 -R sucessfully!
So far, I am liking this drive! -
I have this drive and I am burning DVD-R and DVD-RW discs without ANY problems. My DVD player (Toshiba) will only eat DVD-R and DVD-RW discs so I have not even burned DVD+R/RW discs yet, but the DVD-R/RW discs work fine.
I have been using Memorex DVD-R 4x media and Memorex DVD-RW 2x media if that helps you anything. -
I bought one about a month ago. Burned 3 -R disks and none of them would play in any of my 3 DVD players. They wouldn't play in anything except the burner. It went back to the store.
I have this drive and I can burn all as of now. check out my post
https://www.videohelp.com/forum/viewtopic.php?t=212465&highlight=dru530a -
Mine seems to work well now with - media. check out my post here. https://www.videohelp.com/forum/viewtopic.php?t=212465&highlight=dru530a
I have had troubles with this drive then I did 1 thing. everything is in the post
-Eric
Smart render in Sony Vegas 11 for Sony Bloggie MHS-FS3 mp4 files
By ekendahl in forum EditingReplies: 8Last Post: 27th Aug 2011, 19:41 -
Importing avi (divx) Files in Sony DVD Architect/Sony Vegas
By mltwitz in forum Video ConversionReplies: 12Last Post: 6th Jan 2011, 07:56 -
Wedding Videography Sony HDC 900 or Sony PMW EX3 ? Tapes?
By mek in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 26th Oct 2010, 14:35 -
Sony TVR-460 with FireWire cable 4pin undetected by Sony Vaio Laptop
By vatsyk in forum Capturing and VCRReplies: 4Last Post: 11th Dec 2009, 18:45 -
Importing from SONY HDR-SR1 to SONY VEGAS 8 MPEG Video resolution
By UltimateEnd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 19th Oct 2009, 12:00
