Results 1 to 10 of 10
  1. I noticed my DVD writer's read speed has gone down from past 4x to 0.8x last nite.
    I was using Decrypter to back-up a dvd to my hard drive. Thats when I noticed it was reading it at 0.8x. I tried a different dvd and it was still 0.8x. I remember when I flashed it the first I noticed a jump in increase in read speed. So I flashed it again, but still reads at 0.8x
    Does the writer's read speed eventually go down over time?
    Or is it something I can fix? Or does it depend on what dvd it is trying to read?
  2. Enable DMA
    Device Manager - IDE controller - ...
  3. I haven't changed anything. It should've been that way before.
  4. Mod Neophyte redwudz's Avatar
    USA
    XP has a bad habit of ocassionaly changing DMA settings on it's own. Ripping speed is somewhat dependent on the DVD you are reading, but not by that much.
  5. I just checked and the transfer mode is set to "DMA if available". It also says 'current transfer mode' is "PIO".
    Now what?
  6. Originally Posted by mrhata
    Now what?
    Press OK?
  7. Yes. I mean it was already set that way. I double checked the settings also in the Bios/Cmos area.
    I wanted to add that my dvd-drive is set as the secondary master too. My ide cable wouldn't fit as a primary slave.
    But if I had no problems before, why do I now?
    This thing is too weird.
  8. copy and pasted from the rip speed tip sticky
    Tip #3: Re-install IDE Controller
    Some people on this forum have reported that re-installing their primary IDE controller gave them a boost in ripping speed. I haven't tested this method, so I cannot provide you with many details.
    Steps to re-install Primary IDE Controller (Windows XP)
    Right click on 'My Computer' on your desktop and select Properties. Click the Hardware tab and launch the Device Manager. Press the + sign to expand the tree of 'IDE Controllers'. Right click your Primary IDE Controller and select Uninstall. Now re-boot your computer, and Windows should automatically re-install your IDE Controller.
  9. I guess I technically did that too.
    I finally got over my lazyness to buy a longer IDE cable and make my dvd drive on the primary instead of secondary.
    I made it the primary slave, and when I booted up, it found a new dvd drive reinstalled it, and am now reading up to 4x again. Don't know why it stopped reading that fast in the first place.
    Since I didnt know what the PIO mode was, which was set on the secondary ide, even though it said "DMA if available", I realized the primary ide said DMA mode so I just moved the dvd drive there.
    Either that or just the simple re-install of the drive did it. I dont know, but I'm a happy camper again.
    I hope people learned a new lesson here.
    Thanks for all the suggestions given.
    Feb 2004
    Florida
    I was having the SAME problem, but now, after un-installing and then letting Windows XP RE-install both of my IDE channels (drivers) automatically after rebooting (two times actually). I was running at around 1200 KB/s since I got my DVD-burner last night. I was using DVD Shrink and it was taking over 1 hour and 30 mins. Then I did the above and it started at 3500, and averaged around 3300, which took around 40 mins, instead of the projected 2 hours that it was showing me when I tried doing the same DVD earlier (never let it finish though because it was going to take so long). So, I finally got my original copy of Lock, Stock & 2 Smoking Barrels backed-up
    Then I backed-up my original In The Bedroom. At first I had a problem encoding it because it said that the sectors were encrypted but after trying it again, it went through, with no problems. I had less of a compression % on this DVD then my Lock Stock DVD (Lock = 52%, Bedroom = 62%). This one took me even LESS TIME (around 25 mins) and it was rolling at a READ SPEED when encoding at close to 6000 KB/s.
    I was wondering why the increase in READ SPEED? Was it mainly due to the compression rate - the fact that it was less compressed? The more you compress a DVD, the longer it will take to copy??? I don't know, just asking Thanks
    Dallas22
