i have an mpeg clip that plays fine on the pc but when i use svcd2dvd to author it and nero to burn it onto dvd the video plays fine in my stand alone dvd player but the audio is crap with scratching sounds and clicks, i have burnt two more of the clip but they all seem to be the same.
i have another question aswell regarding svcd2dvd, i create different vts's for different clips then when burnt in nero a message appears sating that the dvd may not work correctly
What was your original file and what did you do to it?Originally Posted by rmc86uk
Also, what are you talking about with the different vts's for different clips? Are you trying to put more than one set of audio_ts & video_ts folders on a DVD? That won't work. All clips in your project need to be authored into one title set."There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
the video is about 90 mins long and it is what i filmed from my dvd camcorder of my mates band.
so what are vts's used for then cos ive probably misunderstood everything. thanks -
What are you trying to do, exactly? Is all your source the same (frame size, aspect ratio, AC3 or MP2 audio, etc) or are you using different types of files? You shouldn't have to use multiple VTSs in the same project if all your stuff is the same. At least that's my understanding of using multiple VTSs.
What settings did you use when you produced the MPEG2 files you authored?"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
Well, SVCD2DVD decompresses the audio to wav, then upsamples it to 48 kHz (loss of quality here) then reencodes the wav (again a loss in quality). Try making the audio 48 kHz with some other tool, if the ones used by svcd2dvd doesn't produce good results.the audio is crap with scratching sounds and clicks
/Mats
Burnt XVID looks awful on DVD
By skribby in forum Authoring (DVD)Replies: 5Last Post: 16th Aug 2009, 12:56 -
burnt dvd's freeze 3/4 through the movie
By sc0rpthir13en in forum Newbie / General discussionsReplies: 8Last Post: 30th Oct 2008, 20:40 -
playing burnt dvd's
By deadgirl in forum Newbie / General discussionsReplies: 4Last Post: 16th Oct 2008, 00:56 -
burnt dvd does not play
By sumeshkri in forum Authoring (DVD)Replies: 12Last Post: 22nd Nov 2007, 02:33
