  1. Hello,
    Can anyone help me firgure out how I am able to convert VOB to MPG with the use of my TMPGEnc. I have placed a screenshot of my wizard below and as you can see it is able to accept VOB as audio. I am unable to re-create this using another PC after copying my TMPGEnc folder.
    Your help will be appreciated. Thanks.
  2. you can't... you can use dvd2avi to setup a d2v file for tmpenc to use.. see http://entiendo.gotnet.net and it will show you how to 'frameserve' a vob file for tmpenc to use..
  3. Member wulf109's Avatar
    Jul 2002
    You certainly can,I have at least 8 versions of TMPEG on my HD and they all open vob files. The video portion since TMPEG will not open ac3 files.
    If you have PowerDVD on your HD it provides the mpg codec to open vob files.
