If it's only pausing once about half way 2/3rds of the way into the movie, it could be your process isn't taking into account the VTS vectors around where the layer change would be. I don't use the software you describe so I'm guessing why you're having problems with that one.
If it keeps pausing, it could be your playback device and media aren't the most compatible.
dvd player without play and pause on screen
By gamazz in forum DVD & Blu-ray PlayersReplies: 1Last Post: 10th Mar 2012, 14:35 -
multiAVCHD prevent pause between tracks
By yoboha in forum Authoring (Blu-ray)Replies: 1Last Post: 28th Sep 2010, 08:17 -
Pause/Record on DVD recorder controlled by camcorder?
By maveni in forum DVD & Blu-ray RecordersReplies: 0Last Post: 15th Jan 2009, 10:27 -
how do i prevent my dvd from being copied
By kareen_630 in forum Newbie / General discussionsReplies: 213Last Post: 6th Jan 2008, 08:16 -
Prevent automatic scaling/zoom of picture when playing a DVD
By pk20 in forum Authoring (DVD)Replies: 5Last Post: 7th Sep 2007, 03:30
