I use SVCD2DVD and think itīs a great prog.
But one question. In ffmpeg is the audio convert rate 128 and i mean the sound isnīt good. When i convert with ffmpeg manually with 226 the sound is much better. Is it possible to change the convert rate for ffmpeg over SVCD2DVD from 128 to 226 ? ( Like over the GUI of ffmpeg or is there any file for a batch line)
THX for advice
It uses the bitrate of the source.
Better quality may be achieve by unchecking FFMpeg in the options.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
5.1 Audio Question
By Simmons in forum AudioReplies: 0Last Post: 22nd May 2011, 10:12 -
audio rippin question
By completetech in forum AudioReplies: 2Last Post: 5th Apr 2009, 10:04 -
question about demagnetizing audio head on VCR to improve audio
By jimdagys in forum Newbie / General discussionsReplies: 3Last Post: 29th Aug 2008, 17:47 -
Video with No Audio Question
By The Monkees in forum AudioReplies: 1Last Post: 26th Nov 2007, 19:06 -
Audio question.
By cowboysroy31 in forum AudioReplies: 2Last Post: 5th Jul 2007, 12:44
