I have a VCD where the picture quality is quite crap - the contrast is on very high - so I wish to put it through an editor and remove it - then re-encode and burn a new VCD.
The thing is - I don't want to extract the whole file just yet, I wish to extract a bit - test this, then if I am happy with the results - I will copy the whole dat file over.
I need to know a program that will allow me to extract part of the dat and then if I cut/cancel the operation - what ever got extracted to my HD - will play without errors. I basically need something like DVD Decrypter - but able to extract dat off a VCD.
Thanks!
Use MPEGTOOL, simple freeware utility.
You can find it at
http://www.digital-digest.com/dvd/downloads/mpegtool.html
Set it to extract a few minutes in the middle of your movie (1 min = 29.97 x 60 = 1,798 frames) -
aguillon,
thanks man, that MpegTools Programme did exactly what I wanted - managed to easily extract whtever time length from the dat file to the HD very quickly, nice app!
best format and size to convert a vcd dat file to for archiving?
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 1st Apr 2012, 03:59 -
VCD Karaoke (MPEG DAT file)- removing the vocals
By tsrusa2002 in forum Video ConversionReplies: 12Last Post: 22nd May 2011, 02:51 -
How to extract each audio channel in a DAT file (from VCD)?
By coxanhvn in forum Newbie / General discussionsReplies: 9Last Post: 28th Apr 2011, 17:06 -
Extract part of an audio file into a new file without rencoding?
By therock003 in forum AudioReplies: 4Last Post: 19th Oct 2007, 16:32 -
How to extract a .wmv file from inside a .dat file
By Toastie in forum Video ConversionReplies: 2Last Post: 17th Jun 2007, 22:06
