I have a problem when I burn my DVD's. The speach starts off ok, but slowly trails away from the video, as in first it happens when the speach.
I notice that the original video [taped my parrot] does not trail nor does the mpeg that i captured the video to.
Why does it trail when I burn the disc? Do I need to split up my movie in to 10 pieces for example? as 10 different chapters or something?
Results 1 to 9 of 9
Please, anyone?
Do I just need to split the clip in to chapters or what?
I can't afford to waste any more discs -
Did you drop many frames when you captured? Are the audio and video streams the same length?
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
Unless you actually provide some information about what programs you use to capture, author and burn, the video format (NTSC or PAL), if you use inferse telecine (IVTC), the audio format, etc, then we can't help you out.
Sorry, but you've provided no information that we can use to help you out. -
Originally Posted by sacajaweeda"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
How can I check for that? I don't have them seperated into two different streams.
They are all together in one mpeg2 file.
Like I said though, the file runs fine on my computer.. but when I burn it the sound trails. -
Use VirtualDubMod to open your file with. Then File>File Information. All the info will be displayed for your file.
I have the same problem also using Ulead MovieFactory 2 wich the DVD's audio seeems to get left behind after a while. does anyone know if Ulead has a program in it were it can be fixed or should I do what was posted before me.thanx for any help
im stupid.....leave me alone.
Blur/Trailing image after driver update
By carlos28355 in forum Media Center PC / MediaCentersReplies: 6Last Post: 3rd Sep 2011, 11:11 -
Encoding trailing effect PAL > NTSC
By KarenM in forum Authoring (DVD)Replies: 0Last Post: 10th Jul 2010, 13:04 -
Movement has a visual distortion (trailing image)
By Twheels in forum Authoring (DVD)Replies: 6Last Post: 6th Sep 2009, 08:59 -
trailing effect on dvd
By D_Shives in forum Authoring (DVD)Replies: 12Last Post: 30th Jun 2008, 07:42 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 18:01
