Sup guys, im trying to figure out whats the most effecient way of connecting my three drives, two being burners. Which ones masters and slaves, what combination? Thanks in advance.
I only know-I know nothing.
Why would you need two burners? In my system, I have the DVD-ROM as Master on the Secondary IDE channel and my DVD +/- RW as the Slave. There are varying schools of thought on this, but this configuration has always worked for me....
Boot primary master, DVD ROM primary slave, DVD burner secondary master, CD burner secondary slave. I use a secondary PCI IDE controller card for my DVD ROM. That keeps slower devices off the primary channel. If you want to go this route, just make sure the controller will work on slower devices such as DVD, CD drives. I use a Promise TX2 PCI controller card (About $40US)
Is zero config a good way to manage a wireless network?
By SingSing in forum ComputerReplies: 13Last Post: 29th May 2010, 15:50 -
ffdshow audio filter config
By THX-UltraII in forum Software PlayingReplies: 0Last Post: 17th Feb 2009, 04:12 -
XP does not recognize my DVD writers as DVD writers thinks they're CD write
By steve1040 in forum DVD & Blu-ray WritersReplies: 5Last Post: 25th Jul 2008, 02:52 -
Config XviD Encoder to control size
By kevin182h in forum Video ConversionReplies: 6Last Post: 27th Feb 2008, 20:02 -
Router config (D-link)
By SE14man in forum Newbie / General discussionsReplies: 4Last Post: 9th Dec 2007, 08:12
