I have always wnated to know how to add my own intro splash screen with sound to the beginning of my dvds...I just don't know where to begin.
Boy do I love my avatar!
Splash screens are just first play titles on the DVD. Use an authoring program that supports first play titles, and you are in business. Most authoring packages support this.
Hi tsantsa,
Just encode your footage, with whatever sound edited in first (before encoding), to DVD compliant MPEG2.
Or... I use TMPGEnc to take a still as the video source and whatever audio you want then encode that to a DVD compliant MPEG2.
Then, as stated already, use the resulting .mpg as the first play track.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
If you want something interesting for the splash screen. I used ulead Cool 3D to make some text jump out at you and matched this with the audio.
Then as has been said selected it as first play (MPEG converted).
Looked good.
If you want to get serious something like adobe after effects will do an amazing job but at the cost of the software and a high learning curve.
Most video editing s/w will give you some effects. -
Thank you !!!!!!!!!!!!
Ive been wanting to do the same thing but i had NO CLUE on what to call it (Splash Screen)
Makes it kinda tough to do a search on how to do it!
thanks again...if i find a tutorial about this ill post the link
The Reason that the grass is always greener on the other side of the fence is because thats where i bury the bodies ;)
disabling splash logo screen on sony dvp-ns55p
By geminidreamer in forum DVD & Blu-ray RecordersReplies: 3Last Post: 9th Jul 2011, 22:20 -
ffmpegX splash screen still showing after registration
By Le Main Event in forum ffmpegX general discussionReplies: 2Last Post: 2nd Apr 2009, 10:11 -
Trying to create a splash screen for my dvd?
By wan2no in forum Newbie / General discussionsReplies: 16Last Post: 4th Dec 2008, 21:11 -
How to add a splash screen at beginning of avi
By Overfloating in forum EditingReplies: 3Last Post: 20th Jan 2008, 03:37 -
Background/ Splash screen patch in the UK
By stavdav in forum DVD & Blu-ray PlayersReplies: 3Last Post: 30th Nov 2007, 10:13
