  1. I have a bunch of short MPEG movies. I am using Nero 6. Do I have to convert these MPEG files to VOB? Which setting do I use DVD-Rom ISO or DVD-Video? If I use DVD-Video, do I just put the MPEGs in the Video_TS file?
  2. Yes you must first convert to a DVD file and then you can burn with the DVD video option.
  3. I'm a Super Moderator johns0's Avatar
    canada
    Use a program such as tmpgenc dvd author to make your mpg files into dvd burnable files,then you can burn them under the dvd-video mode in nero.
  4. So I can't use DVD-Rom ISO? I have to use DVD-Video? What kind of program do I use to convert MPEG to VOB?
  5. Member Sifaga's Avatar
    Aug 2003
    Melbourne, Australia
    which guide are you following ?
  6. What do you mean, which guide?
  7. Member Sifaga's Avatar
    Aug 2003
    Its what i did when i first got here,
    Check the guides section on the left and find a guide to follow
    ie MPG to VOB guide, How to burn with nero guide etc...
    then if you have a problem with a step it would be easier to help you
