Is my Apex DVD player dying? I tried my 1st 2 copied DVD's in my computer and a portable DVD player and they were both freezing and skipping so I tried in in my Apex 600 and it was working perfectly. I was SO happy until 10 minutes in the picture started to blink. I took the DVD+RW out and even turned off the player. Its still blinking on the blue screen. I tried a normal DVD and it still blinks. I hit the PAL button and it stopped but its black and white now. Then after a few minutes it stopped blinking. Anyone have any ideas?
What did it do after it stopped blinkng? If you put a NTSC (USA) disc in the player and then change it to PAL it will show black and white colors.
There should be a reset button on the DVD player somewhere. If not you'll have to go to the Apex website and find the service menu command on the controller. Mine (Hitachi) is Enter+play+next for 10 seconds Then there was a system restore to default factory setting. -
I would un-plug the player for a good hour then try it again. As for the skipping DVDR my guess would be bad media.
MAN DO I FEEL LIKE AN IDIOT! It was the Vertical hold on the TV lol. GO ahead and laugh. I just never had that happen where it would just go in and out like that. If it did it constantly i could see it, but it would be on and off and it first happened with the DVD player on. Then i noticed it was like that on cable tv so i thought ok the tv is dead lol. So all is fixed now. Thanks for the replies I really appreciate it
Old XP Computer Boots to Black Screen and Blinking Cursor
By p_l in forum ComputerReplies: 57Last Post: 13th Apr 2012, 12:45 -
Blinking line of thin white dashes at top of screen
By turbines in forum Capturing and VCRReplies: 15Last Post: 25th Apr 2010, 22:05 -
PC connected to LCD TV | Graphic Card Temp > 55 | TV Screen Blinking
By anoopaythala in forum Media Center PC / MediaCentersReplies: 3Last Post: 27th Feb 2009, 15:23 -
fitting file size to screen to play on standalone DVD
By Dolly in forum ffmpegX general discussionReplies: 7Last Post: 11th Jun 2008, 11:49 -
CD/DVD playback on standalone player is smaller than TV screen...
By xiduk in forum Newbie / General discussionsReplies: 5Last Post: 1st Nov 2007, 17:02
