Hi there,
I have a problem with my DVD backups, every time I convert with TMPGEnc avi with vobsub into dvd MPEG 2. The picture keeps on jumping every few frames Im able to watch it fully but is quite bad for the eye when the picture flics.
Thats the settings I use for TMPGEnc DVD PAL (MPEG-2 720x576 25fps CBR 5413kbps, Layer-2 48000Hz 384kbps)
Video source type: Interlace
Field order: Bottom field first
Source aspect ratio: 1:1 VGA
I have a NEC 2500 writer and Verbatim 4X media which writes at 8x on NEC.
Does anyone have some ideas to this problem of mine.?
Thx a lot
Did you try different media, or slowing down your burn speed?
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
Yeh I have tryed 3 types of media, and results are similliar part from one where each burned DVD would crash through the movie. I do most of the burns at 4x.
Why are you converting? Are the files too big?
Is your frame rate right? Perhaps the source is progressive scan?"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
Im converting avi to MPEG2 so that I can have subtitles in my movie. How do I check if the frame rate is right.?
Sony HDR-SR7 recorded video jumping around...
By MikeZZZZ in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 54Last Post: 11th Feb 2017, 04:23 -
jumping video
By natty in forum Newbie / General discussionsReplies: 8Last Post: 2nd May 2011, 12:27 -
Help: Video jumping/flickering when edited
By toyota200x in forum EditingReplies: 15Last Post: 8th Nov 2010, 08:22 -
EasyCAP w/ Ulead and Pinnacle - Video Stuttering/Jumping/Lagging problem
By Logan289 in forum Capturing and VCRReplies: 0Last Post: 30th May 2010, 15:25 -
Jumping, Stuttering Video
By Smack2k in forum Video Streaming DownloadingReplies: 7Last Post: 6th Jul 2009, 20:36
